Old 07-07-2006, 10:27 PM
eskmo85 eskmo85 is offline
Send a message via AIM to eskmo85 Send a message via Yahoo to eskmo85
Lightbulb Tran Problems
I know about the over heating thing about them but I have some thing that no one has been able to tell me whats wrong with it. The problem is that it is leaking fluid out of places that it should not. Like the air breather on the top and the wire harness on the driver side. I have silicone the crap out of the wire harness so that is what changed the flow to the top at the air breather. I also check the coolant lines to see if its flowing and its fine. The Tranny was recently rebuilt from someone else and it shift fine if you add more fluild to the tranny. I got the Tranny from someone from here. I'm looking to hear good news that its something that I can fix from parts from my other broken Tranny. The broken Tranny has a bad front diff but a good transmission.
Old 07-08-2006, 12:06 PM
what other tranny bolt up to the 92 svx. I talked to some one on here about it but I cant remember what ones do?? I know that ones from a WRX sti 6 speed do but its a little more then I'm looking. I'm looking for a 5 speed out of some thing else. Like a forster I think is one. I don't know if there are any others then that.
Old 07-08-2006, 03:08 PM
Manarius's Avatar
Manarius Manarius is offline
Any EJ Series Transmission will bolt up to the SVX's engine. Just make sure that if you do a swap, get a matching rear differential.
-Jason
-Obi Wan Kenobi
