87 Octane
So... I recently bought a '92 SVX, and I need to get some info. I tried searching and found little that was useful.
In interior Alaska, you can buy diesel fuel anywhere. There is not a single fuel station I have seen that does not sell diesel, unlike down in the states. The tradeoff, though, is the frequent lack of high-octane gasoline; and, while I am readily able to buy $4.45/gallon diesel for my pickup, I sometimes have difficulty finding $3.75/gallon high-octane for my new car. So, the question is, what can I do to the car to allow it to run reliably and safely on 87-octane fuel? Is there an additive available? A way to adjust the timing easily? A magic carburetor that Detroit doesn't want me to know about? Another question, somewhat unrelated... Is there anything special worth doing to an SVX that will be driven in extreme cold? Temperatures as low as, say, -60F? It's been "winterized," which means that it has the normal assortment of engine and accessory heaters. Are there special considerations for the transmission or engine that a different model car wouldn't need? H |
Re: 87 Octane
Re: 87 Octane
+1. Get the ECUtune stage 1 ECU from here (http://ecutune.com/svx-stage1.htm) or PM "longassname" here on the network. His name is Mike and he is the one who runs Ecutune. Just make be sure to tell him that you want the second map to be setup for 87 octane
Re: 87 Octane
Re: 87 Octane
Correct, You wire up some type of switch and then are able to swith between the normal map and the lower octane map
Re: 87 Octane
Nearly twenty years have elapsed since the car was first produced and since then, there have been changes in what was then standard fuel.
I have run on approx. 87 octane, our standard fuel, for more than two years, much of it stop start driving, and have never detected anything near knock or pre ignition. However my car is JDM and fuel rating can not be assumed as accurate, country to country. Run a test and observe.
