Old 09-14-2015, 02:06 AM
subaru subaru is offline
calipers front rotors
Hi All
Does anyone know if there are renewed or new calipers for sale?
The right front caliper is stuck and gives enormous heat
I would rather change both of them
Thanks
Rinus (the Netherlands)
Old 09-14-2015, 04:33 AM
Re: calipers front rotors
I'm quite sure: http://www.rockauto.com/ will ship to The Netherlands.
I've bought a lot of SVX parts from them including brakes.
Old 09-14-2015, 09:22 AM
SVX_MY_BABY's Avatar
Centric makes re-manufactured. I have them on my car and am happy.
http://www.centricparts.com/
They don't sell direct, so you'll have to find a dealer.
They also do repair kits.
Caliper Kits Brake Caliper Repair Kit AWD Front
143.42017 2ea
Caliper Kits Brake Caliper Repair Kit AWD Rear
143.47007 2ea
Caliper Piston Steel & Aluminum Caliper Pistons AWD Front
146.43006 43mm Piston 4ea
Caliper Piston Steel & Aluminum Caliper Pistons AWD Rear
146.38014 38mm Piston 1ea
Calipers Posi-Quiet Loaded Caliper AWD Front Left
142.47016 1ea
Calipers Posi-Quiet Loaded Caliper AWD Front Right
142.47015 1ea
Calipers Posi-Quiet Loaded Caliper AWD Rear Left
142.47506 1ea
Calipers Posi-Quiet Loaded Caliper AWD Rear Right
142.47505 1ea
Peter
Old 09-15-2015, 05:25 AM
theflystyle's Avatar
143.42017 2ea
143.47007 2ea
142.47016 1ea
142.47015 1ea
142.47506 1ea
142.47505 1ea
That is awesome information. Thanks!
1994 SVX LSi
2008 Legacy 3.0R
Old 09-24-2015, 11:50 PM
Thanks everyone
Rinus
Old 11-01-2016, 12:25 AM
143.42017 2ea
143.47007 2ea
142.47016 1ea
142.47015 1ea
142.47506 1ea
142.47505 1ea
Hi SVX-MY-BABY
Could you tell me the name of your dealer?
Thanks
Rinus
Holland
Old 11-01-2016, 08:52 AM
Originally Posted by subaru View Post
Hi SVX-MY-BABY
Thanks
Rinus
Holland
I bought mine through Applied Rotor Technologies when I got my rotors.
They are in California USA. I'm sure there must be dealers closer to you.
http://www.appliedrotortechnology.com/
Have you tried some of Centric's "E-tailers" ?
http://www.centricparts.com/tech-sup...9285&x=64&y=27
Peter
Old 11-01-2016, 09:36 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Pretty sure eBay has them available, no ?
Old 11-01-2016, 12:06 PM
http://www.rockauto.com/en/catalog/s...rake/wheel+hub
Old 11-02-2016, 02:03 AM
Thanks boys
One more question at ordering from the US
Are the brakes in Europe the same as in the states??
Rinus
Old 11-02-2016, 02:31 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
https://www.r1concepts.com/
