Old 07-29-2013, 07:22 PM
steveherman steveherman is offline
starter cranking slow.
Sometimes when hot... very hot my starter lags.
Cranks very slow.
Almost like it wont start... but it always starts... for now.
I have been told to check the big ground wires.
I have replaced the ground wire underneath the battery, the one to the bell housing, and cleaned the tiny one on the fire wall.
Wheat are the locations of the other wires I should I check and clean (or replace)?
Old 07-30-2013, 03:30 AM
Re: starter cranking slow.
Cranks very slow.
If you have checked the two big leads to the starter, the battery terminals, and they are ok, then I would check the battery for a bad cell.
Old 07-30-2013, 05:21 AM
If you have access to a known good starter you could always swap it in to try out. Starters usually just pack it in one day and won't turn anymore, but I had one that gradually got weaker over time. A new starter fixed everything right up. There are a lot of things that can make a starter misbehave, but sometimes it's just the starter.
Old 07-30-2013, 06:46 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure the battery terminals and cable ends are clean. Sometimes you cant see the corrosion on the outside of the connections. Remove the cable from the battery posts and check the inner side.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
