Old 07-28-2013, 02:11 PM
Gamesy's Avatar
Gamesy Gamesy is offline
please clarify svx calipers on a gc8
my friend is convinced that the svx calipers can bolt onto a gc8, can anyone clairfy being true?
i would check this myself but i am nowhere close to my svx
Old 07-28-2013, 03:03 PM
Re: please clarify svx calipers on a gc8
Grandaddy of all WRX's
GC8 = 1992-2000 Impreza sedan 2.0L Turbo
G=Impreza
C=Sedan
M=Coupe
F= Wagon
8=2.0L turbo
6=2.5L NA
Old 07-28-2013, 05:47 PM
Gamesy's Avatar
-_-..... i meant any G series impreza lol
GC8 = 1999-2000 Impreza sedan 2.0L Turbo
G=Impreza
C=Sedan
M=Coupe
F= Wagon
8=2.0L turbo
6=2.5L NA
Old 07-28-2013, 07:38 PM
Subachouli Subachouli is offline
Subaru Parts Guy
I believe they should.
GC8 four piston front calipers bolt onto the SVX. SVX calipers should bolt onto the GC8.
Sourcing the correct rotor to use would be the next issue to take on, though.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 07-28-2013, 08:04 PM
Edited my original post to read 1992-2000 (instead of 1999-2000). Sorry, ipad typing sucks.
Old 07-28-2013, 10:12 PM
Gamesy's Avatar
well thats interesting, my friend is wanting me to buy his 6pot xyz bbk for a gc8 and the rotor is dual bolt pattern. now i wonder if that rotor would still fit
Old 07-29-2013, 06:52 AM
I've bolted STi Brembos into my SVX before. The bolts will fit, but that's the end of the story. STi rotors won't fit an SVX, and vice versa. The caliper mounts farther out on an SVX and necessitates a larger diameter rotor. The SVX also has more rotor offset (the hat section is taller). Also, plan on going up an inch in wheel size from the minimum fitment on his car (ie; if he can get away with a 17", you'll most likely need an 18). Brembos on an SVX don't fit under STi BBS rims, they need 18" wheels.
Old 07-29-2013, 05:53 PM
Gamesy's Avatar
you dont happen to know the offset do u?
Old 07-29-2013, 06:30 PM
No, sorry. I know that we have more built in because my Rota Grids clear the Brembos, while the STi guys need a 5mm spacer with those rims. The difference is in the 5-10mm neighborhood.
