ECU/TCU reporting low RPMs
I "think" the tach is accurate and the ECU is reporting low. I assume this is a sensor issue. Anyone ever have an issue with it?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: ECU/TCU reporting low RPMs
Pls explain - how do you mean "reporting"?
/T |
Over the select monitor. I am using JECScan to read the ECU/TCU parameters.
Error in the definition formula converting the hex to real numbers ?
I had this with the ECUTuner.... ECU and TCU erev numbers were not the same.... /T |
Husky, when you say that you think it's a sensor issue, do you mean crank/cam sensors? I don't think that an issue with those would allow the engine to run, but report the wrong RPM.
Thread Tools | |
Display Modes | |
