Old 07-05-2007, 05:59 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Bearing #s for ac compressor
Anybody got 'em my bearings are starting to go and I'd rather replace the $10 bearings then buy a $200 compressor.
Old 07-08-2007, 06:18 PM
Are you speaking of the bearings on the electric clutch/pulley, or some other ones? I have the same problem with a couple of mine.
Old 07-09-2007, 04:58 AM
SomethingElse's Avatar
word words wording
good luck finding them. I need seals for 3 compressors I think what im going to have to do eventually is dissasemble them myself and call around/ check online stores with the specs. of the parts i need.
Eric
Old 07-09-2007, 06:24 AM
benebob's Avatar
Those be the ones. I don't have a spare at the moment because I'm too nice of a guy and sold it to someone in need so I'd need to take the current one apart to get the bearing size and number. The bearings are easy to find once you have the specs.
Old 07-09-2007, 03:42 PM
I have a bad one. I will see if I can get it apart and then get the numbers.
Old 07-09-2007, 07:16 PM
word words wording
I thought you meant a/c compressor internals.
Eric
Old 07-10-2007, 01:20 PM
wawazat??'s Avatar
Yeah, I'm still around
I'd like to know this info too. I have a dead one that I swapped out recently. I'll scrap the dead one if the bearing isn't available.
Todd
Down to none
Old 07-10-2007, 02:48 PM
benebob's Avatar
Todd
That's funny Todd as long as its a standard bearing its available. You can walk into National Bearing and get any bearing for a Ferarri provided you know the specs or the number.
Old 07-12-2007, 07:04 AM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
What does it sound like?
My car is making a noise and I think it is coming from the compressor. Its a louder whiring sound than normal and when the revs are over 2000 rmp is sounds metalic - like a bearing going bad. Is that what yours sounds like? Thanks!
Old 07-12-2007, 07:18 AM
wawazat??'s Avatar
I know Ben, I was just piling on in this thread. I'll dis-assemble my dead one eventually to get the bearing out for cross-ref.
Funny story about bearings on my Dodge. After the third set of front wheel bearings failed the dealer wanted $1300 to replace them both (bearings were ~$700 of that estimate). Teh bearing is a conglomeration of bearings (2), hub with studs and mount and ABS sensor. Some research showed the assembly was made by bearing maker SKF and instead of almost $350 each at the dealership, a bearing distributor could sell me the same part (minus the Mopar box) for $118 each. As a salesman, I'm all about the margin...until it costs me that is
That said, I decided to do a part-time 4x4 conversion using real Timken roller bearings and Warn hubs for only slightly more than the factory bits
Down to none
Old 07-12-2007, 11:22 AM
My real problem right now is time. I will try to get to this, but if someone else gets there first, great. I will try to do this though.
