Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 04-23-2007, 07:50 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I am so rediculously jelous....... but at the same time cant wait to see what these babies do
~Phil
Old 04-23-2007, 08:05 PM
longassname's Avatar
Just some dude.
The answer to that is nobody knows yet because it hasn't been done. And what's more is none of us will be able to answer your question any time soon as we all got H beam rods too.
Some brave soul will have to put these pistons on stock rods to find out.
Originally Posted by JaySVX
Yet again, my wishlist grows even longer...
Congrats, very nice looking. What kind of abuse can stock rods take, as TomSVX i believe shattered his piston on his one car, not the rod. Could the rods take up to 15psi without worry, as long as the pistons can?
Old 04-23-2007, 09:35 PM
Originally Posted by longassname
Some idiot will have to put these pistons on stock rods to find out.
Fixed her up for ya Mike
Old 04-24-2007, 01:45 AM
Hmmm, how much boost can those pistons/pins/rings withstand?
Old 04-24-2007, 06:14 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Description: These are forged pistons designed for use with either gasoline or E85 and boost levels up to and in the 30's psi range.
That should answer your question.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-24-2007, 09:12 AM
**** I must have been drunk... embarrassing!!
Old 04-24-2007, 10:45 AM
Again, Danny??
Hey, you must know some people who know some people to be even ABLE to get drunk in Quatar!!
Old 04-24-2007, 11:07 AM
cdigerlando cdigerlando is offline
Diameter
We've gotten in the first batch of custom SVX pistons so it's time to start this thread. This piston design is now established for us so we can offer them as individual sets. They will be made available on our website when I revise it for multitude of performance hardware options we are developing (pistons, cam sets, rods, transmissions, forced induction parts); except for the forced induction parts, the other performance parts allready have their own threads.
Price $1090 shipping $30 lead time 5 weeks
highlights:
compression ratio: 8.5
pins: tool steel
valve reliefs: -0.275"
anti detonation grooves
Description: These are forged pistons designed for use with either gasoline or E85 and boost levels up to and in the 30's psi range. They are machined from the strongest forgings possible with emphasis being placed on strength. Appropriate rings are included and optimum ring placement for the application was incorporated into the design. Latteral gas porting was incorporated to facilitate sealing of extreme cyllinder pressures. Tool steel pins were used for maximum strength. Pins are centered as this is better for higher cyllinder pressures. Piston tops are designed for optimum squish area performance, intake charge mix, charge to spark kernel pressentation, flame propagation, and expansion force application.
I'll follow this post with some pictures and some notes trying to illustrate the features.
Excellent specs. CP pistons are supposed to be top notch. Since this seems to be an obvious weak point from Tom's extensive experimentation, I think that this was a smart move. Can't wait to see them. Didn't you also mention that these were 97 mm diameter in a previous thread?
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 04-24-2007, 11:24 AM
JaySVX's Avatar
Originally Posted by cdigerlando
Since this seems to be an obvious weak point from Tom's expensive experimentation, I think that this was a smart move.
Fixed it.
Jay
Old 04-24-2007, 11:32 AM
Fixed it.
Jay
not as bad as you would think. I was able to work a deal with both LAN and the new motor's owner to get out of dodge fairly easily on that one... Now this one will be just a pinch more expensive
Old 04-24-2007, 12:02 PM
JaySVX's Avatar
I defidently want to check it out at some point what your doing with it. Sounds like it's defidently out on the verge of invention.
Old 04-24-2007, 12:39 PM
sure... you are more than welcome to come stop by the shop when I am there sometime... I am going to be devoting most of the garage space to building both mine and Sicksubie's motors. I just gotta finish school and free up some time to get some work done in there
Old 04-24-2007, 12:41 PM
Just some dude.
The pistons themselves are not 97mm. The pistons are for a 97mm bore which is just a light hone on the factory cyllinders. The pistons are 96.9137mm at the guage point.
Just remember to hone your cyllinders to 3.819" = 97mm. The ring set includes instructions on the hone as far as grits to be used and what not though it is pretty standard stuff.
Old 04-25-2007, 07:51 AM
Originally Posted by svxistentialist
Again, Danny??
Joe, I'm Christian, I am buying liquor over here... But is more expensive than usual
Old 04-25-2007, 07:54 AM
Excellent LAN !! Congrats on your achievements so far
