Old 03-07-2002, 09:08 PM
Transmission filter
I have been looking for a canister type transmission filter. I have checked with parts stores, transmission shops (least help of all) and have not been able to find a source. I know they are out there, but I can't seem to find them. I have looked on the net, and no luck there either. I can find pictures of them to look at, but I want to buy one. If you have a source, please let me know where. Thnaks
Old 03-07-2002, 09:24 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
I think you're going to find that most of the canister type A/T filters are just the same as the engine oil filters. They normally use a Fram PH8A or similar. Saturns use a canister filter, maybe check the boneyard for one. I'm not sure of the mounting though. The Subie dealer has the retrofit filter with hoses for the SVX, about $12, a bargain. Also available is a filter from ATP, it's an in-line filter, similar to the Subie filter. It looks like a slightly over-sized fuel filter and is available from most part stores, if you can get them to look at an actual catalog.
Beav
p.s. check: http://www.bulkparts.com/
Old 03-07-2002, 09:28 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Here's what I have currently:
Temp Gauge Autometer #2640:
http://store.summitracing.com/partde...;ATM2640<br />
External canister type filter:
http://store.summitracing.com/produc...earchtype=ecat
I ordered it all from Summit. Oh, the gauge comes with a green bulb sock so don't bother ordering an additional one like I did.
Works good. I have had the temp gauge wedged between the A pillar and the dash for nearly 2 years now...I suppose a pod would be the more correct solution
'20 Honda Ridgeline
http://www.x35design.com
Old 03-08-2002, 04:40 AM
svx_commuter's Avatar
The SVX ATF filter looks just like the filter on the 91 Legacy.
