Old 07-18-2005, 09:16 PM
eskmo85 eskmo85 is offline
Send a message via AIM to eskmo85 Send a message via Yahoo to eskmo85
Cool Looking for a 6 speed for a 92 AWD
I am looking for a 6 speed tran and the paddels for the whole change over. I would like to put a 6 speed in over a 5 speed. I also don't know what 6 speed will fit. I think I have seen a few that have a 6 speed's in there SVX.
Old 07-19-2005, 02:02 AM
ThetaReactor
The only Subaru 6MT is in the WRX STi. There are several versions across the different model years and options packages, differing in gear ratios and front diff setup. Go here: http://www.rallispec.com/Transmission%20chart.htm
[Subaru doesn't make a 6spd paddle shifter. I think the 5spd auto might be available in manumatic form, but I'm not sure.]
Old 07-19-2005, 08:41 AM
mbtoloczko's Avatar
sans SVX
Any of the Subaru 6MTs will bolt up to the SVX engine. The USDM 6MTs all use the DCCD electronically controlled center diff. It would be impossible to wire up the DCCD to work properly on an SVX (unless you wanted to spend thousands of dollars on wiring and sensors). The JDM 6MTs come in three variants:
1) DCCD w/Suretrac LSD front diff -- same as USDM
2) non-DCCD w/open (non-LSD) front diff
3) non-DCCD w/Suretrac LSD front diff
#3 is by-far the most preferred 6MT among the WRX people because no one wants to mess with trying to wire up the DCCD, and the Suretrac front diff improves cornering traction. That tranny is also the most rare of the JDM 6MTs. Very difficult to find a used one. The non-DCCD/non-Suretrac are fairly plentiful.
If you are interested in a JDM 6MT, I import them on occasion. I can usually beat everyone else's price. The trade-off for the low price is that it takes more time for me to get the tranny.
Mychailo
Visit my locker
Old 07-19-2005, 10:20 AM
87f383's Avatar
87f383 87f383 is offline
I can usually beat everyone else's price = ????? Tax season isn't that far away now is it.
1995 Subaru SVX
-Accel Green Filter *
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Alluminum Drive Pulley *
-Stage 1 Shift Kit
-Small Car Clear Lenses and Corners
-1997 SVX Grill
-17" X 7" Enkei Shoguns
*Thanks Dayle! (SVX Motorsports)
1987 Pontiac Formula 350
-Enough (Once I put it back together again)
Old 07-19-2005, 02:07 PM
mbtoloczko's Avatar
sans SVX
Tax season?
Mychailo
Visit my locker
Old 07-19-2005, 02:50 PM
87f383's Avatar
Tax season?
Yes... you know, a tax return?... and this year the battle is between the SVX and the f-body. The wife has been warned to stay clear of it.
1995 Subaru SVX
-Flowmaster Exhaust
-ECU Stage 1 Chip *
-Stage 1 Shift Kit
-1997 SVX Grill
Old 07-19-2005, 03:00 PM
mbtoloczko's Avatar
sans SVX
Ah, I see. :-)))
Mychailo
Visit my locker
Old 07-19-2005, 03:48 PM
EddieSVX's Avatar
EddieSVX EddieSVX is offline
shiftin' an automatic
Send a message via AIM to EddieSVX
Ah, I see. :-)))
What's a ballpark figure for #2 and #3 above?
I'm interested... It would probably be a 6 ~ 9 months timeframe before I do it since my house will be built by then and I'll finally have a garage to work on my projects.
Eddie
'92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92)
'01 Audi S4 (2.7L Twin Turbo - 6MT)
Old 07-19-2005, 03:59 PM
mbtoloczko's Avatar
sans SVX
Usually, somewhere between $3200-$3600 + shipping from me to you. Depends on the price I get on it in Japan.
Mychailo
Visit my locker
Old 07-20-2005, 10:05 PM
Subafreak's Avatar
Superbeast
Yes #3 best bet, and you can use any 5speed WRX pedal assembly for the six speed, Altho the JDM remote resevior is nice to have.
