Old 07-15-2003, 08:32 PM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Getting ready to install my tranny cooler
Whats' up guys
I'm having my Transmission Cooler installed by my Mechanic on Thursday. I got the BMM-70268 cooler from Summitracing.com.
Well, I guess I just want some advice, is there anything that I should let my mechanic know before he proceeds with the installation? I just figured that since so many of you have gotten the installation you might have some advice. One other thing, where can I get that digital transmission Temp. gauge that I've seen in some pics, and how hard is it to install?
Thanks
Old 07-16-2003, 06:23 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Cooler
Hey SVXgarcia. I've been meaning to PM you about the wiring stuff but I can't seem to find it now. Sorry. I got my digital gauge from Summit as well. I went with the Norsdouq or something like that as its green and fairly close to the original color dash lighting. I didn't install it but if you're decent at wiring you could do it. It has like 5 wires or something I think they used 4. Just depends where you want it. I had sender drilled into the pan (which was dropped at the time). Most people seem to put it on the hoses going out of the pan (which would definately be easier).
Old 07-16-2003, 06:32 AM
awdsvx awdsvx is offline
Install
Why not install the coooler yourself. I just did it recently myself, it is not that hard to do. I placed my B & M trans cooler in front of my AC condensor. I just tilted the radiator and ac condensor rearward and slid the trans cooler in front. Not that hard. I also installed a transmission filter at the same time. But here is where you can find the digital gauges, sending unit not included with temp gauge:
http://www.dakotadigital.com/products.cfm?Category=138
Old 07-16-2003, 08:22 AM
I would install it myself but I dont like messing with anything in the engine unless i have step by step instructions. I'm very good with manuals and instructions. But thanks
Old 07-16-2003, 09:43 AM
mbtoloczko's Avatar
sans SVX
Re: Getting ready to install my tranny cooler
Originally posted by SVXgarcia
Whats' up guys
Thanks
There is the question of which order to arrange flow through the auxillary cooler and the stock cooler. I had mine routed first through the stock cooler and then through the auxillary cooler. This is probably better for summer driving because the stock cooler, which runs fairly hot because its in the radiator, can take the first duty of cooling the hot ATF, and then the auxillary cooler gets to do its work.
Mychailo
Visit my locker
Old 07-16-2003, 09:53 AM
Re: Cooler
The site you want for digital gauges is http://nordskogperformance.net They also have a neat little digital plug-in voltmeter
Old 07-16-2003, 10:06 AM
Porter
Re: Re: Getting ready to install my tranny cooler
Agreed. Run through the stock cooler first, then the auxiliary cooler.... or at your option, eliminate the stock cooler and run only the auxiliary cooler with an external filter in a high-airflow location.
