Old 09-20-2013, 08:37 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Wheel bearing seals
Which way do the bearing seals (inner & outer) go on? Spring side towards the bearing? And do they also get pressed in?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 09-20-2013, 09:21 PM
Re: Wheel bearing seals
The open side (spring side) goes toward the center.
Pack them full of high speed/high temperature grease before you tap them in with the correct sized circular device.
For example a bearing race, that fits the outside diameter of the seal...
Old 09-21-2013, 05:03 PM
dannmarr's Avatar
I work for my SVX
Thanks! That is the way I did it. Last time I did not fill the seals or pressed them in. I
Noticed a gap between the bearing and seal (the seals were not pressed up against the bearings).
Could this cause the failure due to dirt or moisture entering?
Subaru SVX for fun
