#31
Re: click click click...start? click click start!
I was always taught to start with the basics...... check the starter and starter connections before going deep into complicated electronic systems.
Chris "A person convinced against their will, is of the same opinion still" New?? Find the downloadable SVX Online Service Manual Here RECOMMENDED READING for newer SVX owners Here some cool info if not fully accurate. Last edited by SoCal LS-L; 08-06-2009 at 09:53 AM. |
#32
Well I am doing the bosch relay mod as well, but I couldn't find a bosch part number in any of the threads concerning the mod. I asked a guy at napa for a 30 amp relay and he showed me a book will a whole bunch of them and asked which one I needed and I said 'good question', so... does anyone know the bosch part number? Thanks
97 Toyota 4Runner SR5, 5 spd 92 Ebony SVX AWD (4.44 gears) |
#33
Keith |
#34
Keith Last edited by kwren; 08-07-2009 at 08:48 PM. |
#35
Keith |
#36
That would be great! I went to autozone and checker and they said they both stopped carrying them and that napa would have it, so I went there and then there were just too many choices
#37
Keith Last edited by kwren; 08-07-2009 at 08:51 PM. |
#38
you would probably want it with a mounting bracket
http://www.opentip.com/Electronics-C...-p-878391.html If this doesn't work let me know Keith Last edited by kwren; 08-07-2009 at 09:05 PM. |
#39
might click the link and print the page and take it with you to the auto parts store.
The relay has the numbers of each connection and shows what the function of each part of it, right on the relay. The numbers should correspond with the numbers on the Busch starter wiring diagram that is floating around. Last edited by kwren; 08-07-2009 at 11:22 PM. |
#40
#41
i'll try this on the weekend....
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
#42
There are two other possibilities for this type problem, and two solutions:
the ignition lock/key assembly fits into the cast housing behind the "security cage" on the steering column. Even the newest SVX's are a dozen years old, now. On my car the key could even be removed while the car was running. At the other end of this cast housing is an ignition switch & pigtail that can look good from the outside but cause the exact symptoms described. I replaced both. It is a good idea to replace the headless "security" screws/bolts with regular bolts or to cut a flat blade screwdriver slot in these fasteners to facilitate removal and tightening. Mine were always coming loose (easily determined when the entire ignition lock assembly rattles and moves around). I was told I "needed a new starter" for about 10 years, from 3 different shops: my original starter works wonderfully and has for 17 years and almost 175,000 miles. Cheers!
' 92 SVX @ 185K ' 91 420SEL @ 223K! ' 88 420SEL I. @ 178K (what a buy!) ' 87 F250 @ 180K ' 93 ZX-11D @ 29K ' 93 SC400 @ 93K 2001 Valkyrie Interstate @ 6.6K (Brynhild) Y2K NightHawk 250 @ 1,500 miles ' 88 420SEL II. @ 208K '85 F150 @ 135K |
#43
