#571
Re: Building a 10,000 rpm NA engine.
The gas just burns to heat up the air. The advantage in raising the compressing ratio is to squeeze the gas into a smaller volume, so that it will have a greater expansion rate when heated. Harvey.
#572
Aren't all explosions an expansion of molecules through heat?
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#573
Depending on the rate of expansion.
#574
Hope you are all sitting down,
I was wondering if the way to increase the compression ratio is to weld the head. Build up volume to reduce the chamber size. So what do you think. TOny
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#575
you'd have to weld the head from the inside out... no?
#576
Adding material and welding into the actual chamber will change the flow characteristics of the chamber drastically, not to mention the risks of creating hot spots. You would need to fully redesign the combustion chamber and add material evenly and completely blend and smooth the chamber out. Keeping in mind the angle opening of each valve and the angle of the spark plug and watching out for the flow through the head.
#577
Tony,
What Tireiron said. I've seen it done on heads before (never EG33 heads!) and you need immediate access to a flow bench and a lot of intense effort so as to not bugger up the works. Better off attacking things from the piston side of things. Cheers, Bill
#578
A turbo just cheats and increases the air density of the intake charge. |
#579
Not sure how you get more air into the chamber Bazza as the stroke volume is still the same. How do you see more air getting in.
Tony
#580
I'll get back to you on this as I've confused myself lol.
#581
There are plenty of computer simulators that can indicate how much increase in power can be expect by increasing the compression my issue with these is:-
- They don't talk about the gains at higher revs, by this I mean if higher compression enables you to move the maximum torques higher up the rev range then the gains are even greater because torque turns to HP. - I have never seen one of these calculators for a flat engine, and my instinct is that our engine behave differently. We have short stroke, big bores, hi valve area. Its a whole different ball game. You can't compare the behaviour of a flat engine to a V8 or straight 6, to do so is a insult to our intelligence. Tony
#582
Tony,
Volume does remain constant, as it is a function of the head and the stroke of the piston. A turbo increases the mass of air within the fixed volume, thus increasing the density of air involved in the combustion events (i.e., the higher the boost - psi - the higher the engine output due to the increased amount of air mass packed into the fixed volume). Cheers, Bill
#583
Not easy to grasp.
When I load a .38 bullet case, I use a certain amount of powder, If I want to get more velocity, without using more powder, I just push the projectile back down into the case further, to reduce the space that the powder is in. This gives a higher pressure, due to the higher expansion pressure. The cylinder is the same, you have a 550cc volume of fuel, if we squeeze this volume into a smaller combustion space, the expansion pressure is increased, so the torque is higher. The torque does not increase as the rpm increases, the resultant torque remains the same. Harvey.
#584
I accept most of what you say, except I think most people believe that there is some increase in cylinder fill as a result of the higher cylinder pressure. Do you think there is a higher fill level from higher compression? Tony
#585
No the cylinder 'fill' won't increase, due to the increase compression ratio. The volume of air we get in the cylinder, changes as the breathing changes, through the rpm range. There will be changes in the Combustion pressure, due to the higher ratio, but this is what provides the torque increase. Don't know if what is what you mean Tony. Harvey.
