Old 09-26-2013, 06:36 AM
Brake rotor
Can they be purchased separately. I have the Cross drilled on the car. I had a caliper dragging and my have warped it. ( is that possible.? ) I thought they were really hard to warp. The guy that did the brakes did not lube the slides. Only drove it 200 miles like that. Checking it out tonight. Where would I get just one cross drilled rotor?
Old 09-26-2013, 07:52 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Brake rotor
John, do yourself a favor and replace both. Its always better to replace in pairs whenever possible. You can find some good ones on ebay. I would order new pads as well. If you want no dust, use the Akebono pads, I have been using them for many years now.
1995 POLO LSI 76K MILES SOLD
Old 09-26-2013, 05:12 PM
Re: Brake rotor
If only one brake is stopping the car. Left rear , would the shutter?
Old 09-28-2013, 12:40 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Brake rotor
ebay if you can wait for delivery
Old 09-28-2013, 01:37 PM
Re: Brake rotor
why not just get it turned? usually $20 per rotor around here. also some people don't realize that some brake lubricants aren't compatible. i see lots of subarus with this same issue because someone used the cheap moly grease from autozone and it combines with the subaru synthetic grease to make a hard glue like paste.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 09-28-2013, 03:04 PM
Re: Brake rotor
New plain rotors are $35 each at Auto Zone. For $15 I would go with new ones. Faster turn around. Take off old replace with new. Not have to wait for Old Tony to fire up the Lathe I want to replace the cross drilled ones I have on the car. Auto Zone wants $115 each.
Ordered on E bay $60 each have them by Wed. Works out good Thurs is my next day off.
Old 09-28-2013, 06:34 PM
SVX92-97's Avatar
Re: Brake rotor
John, are you replacing them yourself or going to a shop
Old 09-28-2013, 07:15 PM
Re: Brake rotor
Myself , cousin has a lift!
Old 10-05-2013, 07:06 AM
Re: Brake rotor
Rotors came in. I did not realize they were so Dang heavy. No wonder the SVX weights so much. Go to be 20 lbs each ( rears). I hope it turns out to be just a sticking slide on the bracket not a caliper. Any thoughts?
Old 10-05-2013, 10:58 AM
gwynethh's Avatar
Re: Brake rotor
and those are the light ones.
Old 10-05-2013, 06:14 PM
SVX92-97's Avatar
Re: Brake rotor
which ones did you get?
Old 10-17-2013, 12:24 AM
SVX92-97's Avatar
Re: Brake rotor
Conn are you gonna show off those rotors
Old 10-17-2013, 05:21 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: Brake rotor
Yes they are super heavy - I got a full set sent to me in New Zealand from R1 Concepts (drilled / slotted / gold passivated).
A lot cheaper than buying OEM locally....
Old 11-03-2013, 04:30 PM
Re: Brake rotor
Here they are.
