Old 03-28-2013, 09:17 PM
common's Avatar
common common is offline
SVX Supercharged
I want to supercharge my svx, im curious if anyone has ideas where i can purchase all the needed materials. Ive got a 92 awd auto h6. Thanks guys, new to this website so bear with me.
ERIC COMMON
Old 03-28-2013, 10:46 PM
Re: SVX Supercharged
There may be one of the ECUTune Stage 3 kits floating around, but it's a long shot as there were only 6 or so made. Beyond that you're basically building a custom setup and will have to select, source, and fabricate most of the system on your own. SVXFiles has some supercharger connections I believe.
Old 04-01-2013, 05:35 PM
common's Avatar
Thank you, Ill look into that, any info on turbos? And happen to know which manual trannys match up?
Old 04-01-2013, 07:15 PM
stiguy's Avatar
stiguy stiguy is offline
Welcome!!
The search tab is you best friend here
But pretty much any Subaru manual trans will bolt up even the sti,s
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 04-01-2013, 09:16 PM
Yep, we have a wide and varied list of transmission available. Any manual that will attach to the EJ series engines will work in the SVX (although a 2008+ will need some electrical trickery to make the speedo work). I've got a 2007 STi 6-speed in my car.
Regarding turbos, unfortunately there are only a few people with a turbo SVX. However, many more have taken the EG33 and put it into a different platform and then boosted it. Done right, it's possible to get over 1000 HP from the engine (See this thread)
Probably the best turbo setup in an SVX is this one, belonging to Phast SVX.
Old 04-07-2013, 01:31 PM
common's Avatar
thank you guys so much! Ill look into that info.
Currently registering for the 2013 bullrun
Old 04-08-2013, 09:07 AM
BRZCory BRZCory is offline
Michigan you say?
<- supercharging his EG33 swapped Impreza. (in Ypsi)
I don't think my setup will work for the SVX guys, as I'm going to incorporate a TMIC into the system.
a 5-7psi non-intercooled turbo setup is said to run ~280hp. But you'll need to look into tuning options, as the stock MAF and injectors max out just above stock power levels. ECUtune sells a stage 2 chip that allows a Z32 maf and nissan 370cc injectors which should *theoretically* be good up to about 500hp.
Old 04-08-2013, 09:26 AM
Originally Posted by BRZCory View Post
Michigan you say?
370cc injectors aren't big enough to get you all the way to 500hp. It you up the fuel pressure, you should be able to hit about 400.
Old 04-09-2013, 02:11 AM
bishop bishop is offline
This, I want to see this, An svx in a well known and well veiwed ****, sorry, its not a race is a rally. :wink:
