Old 07-21-2008, 01:05 AM
togan07 togan07 is offline
Re: Power Steering pump is gone...
Originally Posted by mysvxrocks View Post
Well, really it depends. The last couple days, its done it when I first start the car for a few seconds. Then it does it again as soon as I touch the wheel. When I get home I will try to tighten the belt, and I will put some dressing on them as well. Hopefully that will help. It is quite annoying when it does it... makes an awesome car sound like crap
Hey buddy I'm about 80% sure I know why your car is squealing. If you did what I did when I first changed the power steering belt I accidentally put the bottom pully on the reverse side and thus was not able to tighten it correctly so the pully did not move with the belt and this caused it to SCREAM and I mean scream and squeal loud. Check to make sure your pully is rotating, then make sure you didn't tighten the belt too tight,(where it has no give what-so-ever.)
As for my situation, its not the ring, the pump is completely shot. It makes no noise as I've replaced about everything I could replace but the pump itself, I just have no power steering and its hard as hell to turn :P
Old 07-21-2008, 01:25 AM
zukiru's Avatar
zukiru zukiru is offline
Winona is my yang.
take the pump off... cap the lines, enjoy free HP.
Old 07-23-2008, 09:11 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
So I FINALLY went out and checked things out... And the belt was quite loose. So I tightened it down quite a bit, and started it on a cold start and not one squeal. Then the big test, hard over the wheel... and no squeal! Hey I rhymed, lol. So I hope my problem is solved!
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
