Old 07-13-2008, 11:28 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
My car is making a creeking kind of noise
Its kinda hard to describe, but it seems to do it mostly when either Im at about 20mph speeding up, or about the same speed when slowing down. It sounds like a frog is under my center console almost. I would like to figure out what it is, but I really dont have a better way to describe it. Has anyone ever heard of something like this? Sorry I cant be much more of a help... -Dennis
D.J. McPhee
2006 Infra-Red Ford Focus ZX3 ~ 67k
No longer SVX'n, Ill always miss them!
1995 Polo Green LS-i ~ 95k
1992 Dark Teal LS-L ~ 145k (04/91) #2231
Old 07-14-2008, 09:57 AM
kwren's Avatar
kwren kwren is offline
Re: My car is making a creeking kind of noise
We live in Washington state as well... rains some...we also have a bunch of frogs in our area.
Sorry no more ideas for you yet. Will keep thinking about it though and may can come up with more help! (probably won't be able to though)
Keith
Keith
Old 07-14-2008, 10:12 AM
Very theatrical signature Keith. It's a Texas thing, I expect.
mysvxrocks what you are describing could easily be the noisy baffle plates in the exhaust centre box.
The reason I say that is because you are hearing it at about the same speed most people notice this. [It could be a number of things, but possibly eliminate this one first.]
What people do is cut out this section and replace with a straight through pipe. This changes the sound of the car, makes it a little harsh and flat, but some people like that.
This rattle or buzz from inside the car sounds like it is coming from below the gear change on the console. This is where this middle box [called a resonator] is situated. The loose baffles inside it are affected by sympathetic vibration at the speed you mention, and they tend to groan or rattle.
If that's what you have it's not too serious, but it's annoying on an otherwise rattle-free car.
Old 07-14-2008, 01:53 PM
kwren's Avatar
Yup!...............
Old 07-14-2008, 02:17 PM
mysvxrocks's Avatar
Well that isnt bad news to me... I was going to get it cut out anyways. I know its bad. You can tell on the outside, its got a bad buzzing noise. I hope its that. As that is like $50 to have it cut out, and have a straight pipe there instead. I kinda like the sound of it like that, I did it to my Focus.
D.J. McPhee
Old 07-14-2008, 03:15 PM
Well if you are going to do that, you will be fine.
One little piece of advice, feel free to take it or leave it. Hold on to the resonator box that you cut out from the centre when you replace with the straight pipe.
It is possible to cut open this resonator around the periphery, tack weld or braze the loose plates back into place, weld back on the lid on the resonator box, and it will be good as new.
You may not actually like the sound when you hear it with the resonator removed. It is blarey and flat, rather than deep and rumbling, if you know what I mean. Having repaired and put back your resonator, your SVX will sound like new.
The other reason you might want to replace the resonator is because it helps gas velocity which gives the engine better torque and power at low revs. It won't feel a lot different, but it will actually be down a few clicks on torque with the resonator out.
Your choice.
Old 07-14-2008, 10:04 PM
mysvxrocks's Avatar
Well, see heres the issue with all that. I know nothing about welding. I took a class in high school, and I failed my goals hard
However, has anyone on here tried this? I was considering this...
http://svx-motorsport-accessories.st...svxhiflre.html
D.J. McPhee
Old 07-14-2008, 10:21 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
i had my center resonator replaced with probably about 3' of 2.5" piping.
i personally like the sound much better. a bit more growly kinda
what Joe was suggesting about fixing the resonator and putting it back on is completely past me, so no help from me there...ill stick with the 2.5" pipe
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
