Old 06-21-2008, 11:47 AM
NAMDAM NAMDAM is offline
Help Asap Plz
Broke a bolt on passenger side valve cover top 3rd one back any quick fix?? will it leak if i just leave it broke off in there? How would i go about getting it out?? thanks
Old 06-21-2008, 12:40 PM
Hondasucks's Avatar
Subaru Technician
Re: Help Asap Plz
Take the valve cover off, and if it's not broke flush with the mating surface you should be able to get it out with some needle nose vise grips. If it's flush, I've had success tapping the bolt in the direction it needs to go with a small chisel until it's out far enough to grab with pliers.
It will most likely leak without that bolt in there, although it probably won't leak all that bad since it's at the top, but I'd still recommend getting it out and putting a bolt in. Those are 8mm bolts, so they do not have to be very tight, I forget the exact spec but it's something like 18 ft/lbs, so basically snug with a 1/4" drive ratchet.
1986 VW Jetta
Old 06-21-2008, 01:00 PM
Re: Help Asap Plz
An easy out will work too after drilling a hole. Good luck with the project.
I would fix it and not leave it as well.
Old 06-21-2008, 02:18 PM
Re: Help Asap Plz
Good advise here man... Although I have had success removing bolts with a spring loaded center punch like you did with the chisel.
Old 06-21-2008, 03:32 PM
Re: Help Asap Plz
Actual Subaru specs;3.3-4.0 ft/lbs.
Old 06-21-2008, 03:40 PM
kwren's Avatar
kwren kwren is offline
Re: Help Asap Plz
I was just thinking... 18ft lb with a 1/4 inch ratchet might punch a hole in your hand!!
Keith
Old 06-21-2008, 08:11 PM
Re: Help Asap Plz
Keith
Only if you have soft little girle hands!
Old 06-21-2008, 08:18 PM
kwren's Avatar
Re: Help Asap Plz
Old 06-21-2008, 08:38 PM
Re: Help Asap Plz
Hehehehehehehehehehehehehehehehehehehehehehehehehe hehehehehehehe
Old 06-21-2008, 09:05 PM
Re: Help Asap Plz
WOW!!! What kind of gasket sealer is used for this job?? Im pissing oil worse than I was before i did this on the driver side it looks like its bottom near firewall...If I cant figure this out you'll be seeing my car on the for sale forums its nothing but a headache
Old 06-21-2008, 09:09 PM
Hondasucks's Avatar
Subaru Technician
Re: Help Asap Plz
lol I think I was thinkin inch pounds! I know they aren't that tight, I've never actually torqued mine, I just snug them, never had a problem with them leaking. I don't use any sealant on them, aside from a dab of fuji bond in the corners to keep it from falling out of the cam cover while you are putting it back on.
1986 VW Jetta
Old 06-21-2008, 10:05 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Re: Help Asap Plz
what ive always done to remove broken bolts is to use a dremel tool and one of the disk bits so you can dremel out a line/notch in the top of the bolt. then just use a flathead screwdriver to unscrew it
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 06-22-2008, 09:12 AM
Re: Help Asap Plz
You need to use new gaskets when you do them... Just using sealant will probably worsen the problem.
There should be 6 spots to use sealant. On the 4 seams of the half moons on the back of the head.. There are small indentations on the gaskets there. Also in the front corners where the inner covers meet the head.
Old 06-22-2008, 07:13 PM
Re: Help Asap Plz
Jobs done thank you all next week front main!!! wish me luck thats my last leak spot
