Old 06-18-2008, 10:59 PM
Wolfy's Avatar
Wolfy Wolfy is offline
Send a message via AIM to Wolfy
this shift kit ok?
ok found this, it says its better than the smallcar shift kit.. here
Old 06-18-2008, 11:17 PM
Wikedjuggalo's Avatar
Rebuilding
Re: this shift kit ok?
:P Need to fix your link but yes a member on here made it as far as I understand it works good. FYI the seller is Budfreak just if anyone was skeptic of the seller. Check oab post in Mod section for more information
Old 06-18-2008, 11:42 PM
It's Just Eric's Avatar
Missing in action
Its a bit controversial as to whether or not the spike in hp between shifts is especially good for the transmission. then again the same can be said for the small car kit, ect. and both sides will argue ad infinitum with only testimonial or theretical evidence.
To me, id just buy it and see what breaks, if anything. Then again, I have plenty of access to parts, tools, and have a spare svx to drive... fwiw Id imagine the rear output shaft shearing from the transfer drum would be the first thing to break...Meaning the car would still drive just fine, but it would be rendered fwd
R.I.P Cool Signature.
Old 06-19-2008, 12:08 AM
kwren's Avatar
kwren kwren is offline
The transmission actually works great the way it was made.
My smallcar shift kit ended up in the trash after a couple of months on a rebuilt transmission bit the dust.
Keith
Old 06-19-2008, 12:59 AM
Keith
Keith I agree.
One of the reasons I purchased my car was the excellent automatic transmission. This was a requirement for my wife, but it was something I had to live with.
Interestingly, mine has operated faultlessly over eight years, with a lot of city driving.
Cheers, Trevor.
Old 06-19-2008, 01:19 AM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
mine tranny was rebuilt at about 30000 miles i think as that is what is etched to the top of it, 30714, or something like that, and im pretty sure its the mileage. it still works fine, just added a tranny cooler, so it went all that way without one (at 142k miles now). sometimes i think that its getting weak, and im heading towards a rebuild, but it holds up, no missed gears, slipping, nothing. and im not sure how it was treated before me, all i know is the fluid in it was the most terrible smelling, old burnt crap you can imagine, so im guessing it wasnt treated well.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 06-19-2008, 11:19 AM
Wolfy's Avatar
Question Re: this shift kit ok?
not to sound stupid, but does you shift kit make your car chirp? i just bought mine, and mine likes to chirp once and a while... (the car, not the shift kit) i honestly dont even know if the car has a shift kit in it, although i do have some hints on a rebuild. my car has 135k on it and shifts clean and smooth.
Old 06-19-2008, 12:37 PM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Keith
I agree as well,
I removed mine after the tranny started going downhill. Seeing no improvement, I re-soldered the wires and put it back in adjusting it to "harder" shifts and it made no difference.
I don't blame the shift-kit for my transmission's demise, but I don't think it did it any good. I think what really killed it was a mal-adjusted break band and 4 or 5 years.
After the tranny got real bad I just wire nutted the stock resistor back in there cause I was sick of fussing with it and figured it mattered none anyway.
When in doubt, trust the Japanese Engineers.
Old 06-19-2008, 07:15 PM
Originally Posted by greggbzz View Post
I agree as well,
I have to make the distinction, my Quick Change is nothing like the Small Cars Shift Kit, that was the result of somebody accidentally finding that the shifts felt harder when their dropping resistor went open circuit.
Doing this just raises the line pressure in relation to the throttle position. Unfortunately this causes a few other problems with the normal action of the auto, without actually increasing the engagement pressure to prevent the band or clutches from slipping during the change. Flashing Power light, and problems engaging of the over-run clutch happen.
My Quick Change was the result of researching the process that the TCU and gearbox used to preform the changes. My unit is designed to work in with the normal process, but to safely alter the action to allow the band and clutches to operate at a higher engagement pressure, that prevents any slip during the changes.
This is why it can allow the changes to be made without dropping the engines torque.
