Old 06-12-2008, 09:12 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Brake noise
I just replaced my front caliper yesterday and now I am getting a banging noise when I hit the brakes. It sounds like 2 pieces of metel hitting each other for about a half second then goes away. Also the brakes feel fine and work, just don't know what this noise is.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-12-2008, 10:36 PM
Re: Brake noise
Something is loose, and moving with the disc, till it hits the end. Check the caliper bolts, and the caliper slide pins.
Old 06-12-2008, 10:52 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Re: Brake noise
i had a similar problem when i did mine
found out that a bolt was loose and the caliper was hitting the rim when i applied the breaks.....so take the tires off and wiggle the calipers
best of luck
