Old 04-12-2007, 11:18 PM
Nomake Wan's Avatar
Retired
Looking for a photo...
Anybody have a photo of the interior of the car at night with the lights on? I'm trying to figure out exactly which parts are shot lighting-wise, but I'm not positive what's supposed to light up and what isn't. If the picture could include the instrument panel, center console and shifter, that would be best. Or just a picture of each. Thanks.
Old 04-13-2007, 12:52 AM
Here is what SHOULD have illumination when your lights are on.
Besides the general illumination of the instrument panel, gear selector and climate controls, here is a list of the switches/ buttons that should be illuminated:
Overhead switches:
The wording in the row of four buttons that say SPOT DOOR ROOM SPOT should illuminate green.
The sunroof open and close switches are not illuminated.
Dash buttons
The words on the CRUISE and SECURITY buttons and the FOGLIGHT symbol, on the left side of the steering column should illuminate green. They also have amber LED's to show when they are on.
The symbol on the REAR DEFROST button on the right side of the steering column, should be illuminated as well. An amber LED confirms when it is on
The red triangle on the HAZARD button should illuminate red.
Lower dash (left side)
The symbols in the HEATED OUTSIDE MIRROR switch and the PARKING LIGHT button next to it, should illuminate green. The heated mirror switch has an amber LED to show that it is on. The parking light switch has no amber LED indicator on the 1992 cars. (On my 96, there is an amber LED in this switch to show when it is on, the 92 does not have this LED)
The MIRROR control button has no illumination for the word "MIRROR". However the four directional arrows that are on the round button should illuminate green.
The only button left is the small green light in the AUTO button in the driver's side window power switch cluster. The word AUTO, like on the mirror switch does not illuminate. No other window buttons have illumination.
Old 04-13-2007, 01:04 AM
SubaRyu's Avatar
SubaRyu SubaRyu is offline
Domo Arigato
Wow this is very helpful. I'll check mine tomorrow. I'm pretty sure I have to get a lot of replacement bulbs..
-Ryu
Links:
2004 Honda S2000 (2008~)
1992 Subaru SVX LSL Liquid Silver (2007~2008)
1996 SVX LSi Bordeaux Pearl (2006~)
2002 Lexus IS300 Sportcross (2005~)
1992 Subaru SVX LSL Pearl White (2001~2005)
1994 Mercury Sable GS (1999~2001)
1/43 Scale SVX Models
[SIGPIC][/SIGPIC]
Old 04-13-2007, 01:50 AM
Nomake Wan's Avatar
Retired
Oh... oh wow. Um... wow. A lot more than I thought.
The only things which illuminate on my '92 are:
-Instrument Panel Gear Indicator
-Climate Control Selection Buttons (not the text, the buttons)
-Climate Control Temperature Selector + LCD
-Clock
-"Active" lights on defrosters, foglights and cruise control
I've got a lot of work ahead of me...
Old 04-13-2007, 08:16 AM
SPOT DOOR ROOM SPOT - wording on overhead console illuminated green
CRUISE - wording illuminated green (amber LED when active)
FOG - symbol illuminated green (amber LED when active)
SECURITY - wording illuminated green, ( red LED flashing unless the security system is turned off or the ignition is turned on)
REAR DEFROSTER - symbol illuminated green (amber LED when active)
HAZARD - triangle illuminated red . (Does not flash when activated)
HEATED OUTSIDE MIRROR - symbol illuminated green (amber LED when active)
PARKING - symbol illuminated green (no amber LED on the 92)
MIRROR CONTROL ARROWS- directional arrows on round button illuminated green
AUTO POWER WINDOW
- LED illuminated green on this switch
The wording on the mirror control is not illuminated.
The word AUTO on the power window switch is not illuminated
The sunroof buttons are not illuminated
The chart that shows the part numbers for the bulbs can be found in the How-To documents HERE
Old 04-13-2007, 09:15 AM
dcarrb dcarrb is offline
Is there a lamp replacement how-to around showing disassembly of the cruise, fog lamp, security buttons, et al?
(Pardon the hijack.)
dcb
Old 04-13-2007, 09:19 AM
Nomake Wan's Avatar
Retired
Also, the How-To docs do not list the part #s for the instrument panel lights, only the gear indicator lights (which, oddly, are the ONLY thing on my instrument panel which actually work). Anybody got those numbers?
Old 04-13-2007, 09:22 AM
Just pull out the switch assembly from the dash. There are no screws holding it in place. It helps to adjust the steering column so you can reach in behind the center edge. Once it is out, you will find little plastic caps with a phillips head in them. Those are the bulbs, give them a 1/4 turn and pull them out, sometimes you will need pliers to pull them.
The cruise cluster, hazard cluster, heated mirror cluster and mirror cluster can all be pulled out. Sometimes you need to use a small screwdriver to help pry, just be careful not to damage the surrounding trim.
Te overhead panel is held in place with screws behind the map light lenses.
Old 04-13-2007, 09:56 AM
Cool; thanks.
dcb
Old 09-20-2010, 01:03 PM
Re: Looking for a photo...
When you pull out the switch clusters from the dash, the illumination bulbs are inside the BROWN sockets They are the ones closest to the face of the switch panel.
The BLUE sockets towards the rear house the indicator lights. I have never had to replace those.
Old 09-20-2010, 02:31 PM
Great thread, I was wondering how I would change those. Thanks people.
