Old 01-12-2007, 07:12 PM
etz bseder etz bseder is offline
I could use a bit of help
I am going to be replacing my rear speaker shelf, and was wondering what the easiest/quickest way of removing it to be replaced would be.
I also am having a problem with my rear wiper moter. It tries to move the wiper but can only just barely nudge it. I need to know if there is a problem with a fuse or just that the moter is dead and i have to replace it. In that case I am going to have to purchase one and get a little help on how to replace it.
'92 LS-L, exhaust, intake, audio, ecu 1V4?, hyper ground kit.
Next changes ... PAINT, fix engine problems, 4.44. (GONE)
'97 Impreza Outback Sport, magnaflow muffler, cold air intake, Alpine Type S, MP3/iPod deck, NGK wires, etc.(GONE)
Old 01-12-2007, 07:16 PM
SomethingElse's Avatar
word words wording
you gotta pull the bottom rear seat out and pull the rear trim panels off then remove a screw on each side and pull the shelf out towards the front of the car.
try to tighten the nut on the rear wiper before you replace it. mine was loose when i first got it.
Eric
Old 01-12-2007, 07:55 PM
Thanks, but where is that nut located, what should i be looking for?
Old 01-12-2007, 08:19 PM
word words wording
at the base of the wiper theres a cover, pull up on it and put a 10 or a 12 mm socket on it and make sure its tight b4 you throw parts at it.
Eric
Old 01-12-2007, 09:54 PM
If that doesn't fix it, it is probably the motor. I hope not.
Old 01-12-2007, 10:41 PM
I'll get on doing all these things when the weather makes it tolerable to work on my car. btw, the rear fluid isn't working either, is there an easy way of fixing that ??
Old 01-12-2007, 10:53 PM
excellent advice!!!!
had the same problem on my Porsche, took the motor and gearbox (complicated pantograph setup ) apart, only to find the nut holding the wiper arm to the base of the windshield was loose.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 01-13-2007, 12:19 PM
yay
that fixed my wiper arm, but i am in need of a spaker shelf, and still am trying to figure out how to fix the rear wiper fluid sprayer. the tank is full, but there isn't any spray or leaks.
Old 01-13-2007, 12:28 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Check to make sure you're getting power to the pump for the tank.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-13-2007, 12:58 PM
How would i go about doing that?, i have no idea where to look, but i will have the speaker shelf off soon to replace it.
