Repainting centre caps
I've pulled my centre caps off my OEM wheels to repaint them.
The car is being sold, so it doesn't have to be flash or an exact match. Has anyone been down this path before and can tell me the name of the right colour to get a good match ? Preferably in Duplicolor. Thanks Shane |
Re: Repainting centre caps
I also want to do this - there are others who have done this...a how to would be great.
They have a version of silver called Hot Pink that is a good match.
Hi Shane.
Had to do mine. Green car so did them in gold (spraycan)-marine poly over the top. I know its not original but doesnt look too bad. check photos on donmac45.blogspot.co.nz regards Don |
How about some pictures folks?
