Check Engine codes, Power Steering Leaks
Hi, looking for some advice.
1) My power steering rack has the boot torn apart on the right side and needs replacement. The dealer says the PS pump looks like it might be leaking too. I did the o-ring replacement, and the leaks aren't bad (smells a bit dripping on the exhaust, but doesn't drip much on the garage floor at all). Question: should I get the PS pump replaced along with the rack? (I'll buy aftermarket parts, but I'm kinda stuck with my dealer to install). 2) I'm showing check engine codes: 37 Oxygen Sensor #2, left side 24 Idle speed solenoid control valve 28 Knock sensor #2 (left side) 29 Crank angle sensor (no. 2) 56 EGR system I cleared all the codes and got the same ones again almost immediately. After reading thru previous posts, I'm inclined to replace the oxygen sensors first, and see if that "fixes" all of the codes...thoughts anyone? Also, the check engine light is still intermittant, it's been that way for 8 or 9 months, though the light is on now maybe 70-80% of the time. Its a 92, with 156,000 miles. Last edited by rlutz; 06-28-2008 at 05:47 PM. |
Re: Check Engine codes, Power Steering Leaks
You will need to get a special tool for oxygen sensors its not hard just jack of up the car on one side and replace its easy I promise
I removed my O2s without a special tool, but they are easier to remove with this tool. It's just a crescent wrench with a gap for the wire to pass through.
If you have time and plenty of patience, you might be able to put in the rack yourself. The dealer will charge a lot. Leaky racks are common. Leaky PS pumps are also common. I don't know if many have replaced the actual pump. You definitely should look at everything. It's easy enough to pull the electrical plugs and just look at the sensors. They could be filthy.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 06-28-2008 at 10:11 PM. |
Keith |
I removed mine (with a box end wrench) because I needed to drop the exhaust, not replace the sensors so I left them connected electrically, and at 16 years I wouldn't exactly call it a "quick" disconnect.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
28 Knock sensor #2 (left side) 56 EGR system What would you guys try next? Should I buy a new knock sensor, or just try to get at it to clean it? What should I think about on the EGR system (I changed out the PCV valve about 4 years ago...) |
16 years to disconnect the connector is just a rumor. Takes much less time. More like a couple of minutes.
Hi,
you could check the Knock sensor... If you tell me how, I could send you a picture of the manual's page about it. If it's electricaly sound then you could take it off and clean it where it sits and under the bolt head and then refit it torquing it to fifteen to eighteen foot pounds. Might pay to do that job and check it's electrical resistance at the same time. If that doesn't fix it then I would have a listen to the motor to make sure there are not any knocks coming out... worn pistons for instance. The EGR valve may need cleaning or there could be a hose off somewhere. alve may need cleaning or there could be a hose off somewhere. |
Thanks thats not a bad idea. I seem to be having a similar problem with my car. I'll try it out and let you know the out come.
You replaced the rack? How much did you pay for another one? Also, did you get one rebuilt or something?
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1½" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k At least it's going down..
Ok, that was mildly amusing.
Well,
I replaced the EGR valve, but still get the same codes (28, 56). I'm thinking I'll take off the battery cable, and really clear out the codes. What would yo try next on the EGR system? Temp Sensor? Control valve? |
I replaced the whole EGR system (EGR valve, controller, hoses, EGR temp sensor). I'm pretty sure my "code 56" was from the temp sensor, as it was very gunked up when I removed it. I'd say replace (or at least inspect/clean) that one first, it's the easiest thing to access anyway. Replaced the heater hoses, radiator hoses, fuel injection hoses and fuel filter while I was at it. Engine really purrs, and idles like a dream. Nice to drive without the CEL on... Thanks to whoever posted the vacuum line renewal "how-to" document. The instructions, pictures, and parts list were invaluable. Took me ~15hrs to do it all (I work slow), but managed to put everything back in the right place the first time. |
