Rumbling?
Only had the car for a couple weeks and there seems to be a wining/moaning noise comeing from the rear? sounds like someting winding up! same in every gear just gets faster? apart fro that she seems quite good.. any ideas what this could be? thanks
Re: Rumbling?
Your case should be a bearings issue. You should check your rear wheel bearings.
Re: Rumbling?
My first thought would be bearing. Other than that, rear diff (if you have awd), or binding.
Re: Rumbling?
I would suspect nearly 99.999% that it is a bearing issue.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
Re: Rumbling?
ahh haa wheel bearing it was!! thankyou
Re: Rumbling?
This is the technical section |
