Old 04-22-2007, 10:59 AM
comp_jas comp_jas is offline
Charcoal Canister Lower Hose
I just finished changing the spark plugs and noticed a hose from what appears to be the bottom of the charcoal cannister hanging loose. Where does this go?
Old 04-22-2007, 11:23 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
edited below
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Old 04-22-2007, 12:47 PM
scoobymal's Avatar
Smile
On my UK svx,I have a pipe which plugs into a hole in the engine bay/inner wheel arch,it is opposite the coil packs/spark plugs/I presume it is a vent/breather,mine sometimes pops out,it is easily pushed back in.
Mal
Old 04-22-2007, 01:49 PM
jman050's Avatar
Its a Classic!
Mal
^^^you are correct it plugs into the wheel well area in the engine bay
I was thinking about one of the other top hoses
[SIGPIC][/SIGPIC]
Old 04-22-2007, 04:20 PM
Trevor's Avatar
Trevor Trevor is offline
The hole is not easy to locate and it may help if you take into account that the tube there as a means of venting the canister to outside of the engine bay.
Trevor, New Zealand.
Old 04-23-2007, 09:59 AM
svx_commuter's Avatar
On the USA model the bottom canister hose vents into the fender wheel and in this fender well is the air intake for the engine.
I think that if you live in a hot climate, the evaporative emission system can not be handled by the "normal" system. So the overflow or extra vapors goes into the engine air intake and burn in the engine.
It helps to keep our planet green.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
