Old 10-28-2011, 10:27 PM
kjoyes kjoyes is offline
Altinator MOD.V4 Supplies?
Hi i am doing a altinator mod. v4 here is a neat little store that i bought some of my battery supplies.
http://stores.ebay.com/Genuinedealz
if you take time a do your own looking around you can find the supplies you need there and no shipping.
i bought my knukonceptz 4 gauge 3ft. of red and black for the wires
at amazon.com
http://www.amazon.com/KnuKonceptz-Ko...861109&sr=8-14
http://www.amazon.com/KnuKonceptz-Ko...861109&sr=8-15
and knukonceptz ring terminals
http://www.amazon.com/KnuKonceptz-Ga...861253&sr=8-35
littlefuse mega fuse holder
http://www.amazon.com/Littelfuse-298...9861628&sr=8-1
the little fuse 100amp or what ever one you want.
http://www.amazon.com/Littelfuse-MEG...9861746&sr=1-5
here is some learing information on size wire and stuff for you brain smart guys
http://stores.ebay.com/Genuinedealz/...elp-Guide.html
I have a question about the 2 altinator plug wires that gets Ligthened and put under the manifold.
they are 2 different gauges of wire.
what are the gauges? can the be up graded to a larger size?
2 wires and how do you go about lenthing them cuting the wire? thanks.
Old 10-29-2011, 11:38 AM
Re: Alternator MOD.V4 Supplies
Originally Posted by kjoyes View Post
I am doing the alternator wiring mod. v4. Here is a neat little online store where I bought some of my supplies
If you take time a do your own looking around, you can find the supplies you need there and no shipping.
KnuKonceptz Kolussus Flex Kable, 4 gauge power wire, red
KnuKonceptz Kolussus Flex Kable, 4 gauge power wire, black
KnuKonceptz Ring Terminals
Lttlefuse MegaFuse Holder
LittleFuse 100A MegaFuse
Fuses also available in 125A, 150A and 175A. I started out with 175A and slowly went down to 125A (mainly because I have a 160A high-output alternator.
Here is some learning information on wire sizes and related stuff for you brain smart guys.
Much more detailed and usable technical information for automotive use can be found here:
http://www.maniacelectricmotors.com/technical.html
I have a question about the 2 alternator plug wires that get lengthened and put under the manifold.
There 2 different gauges of wire. What are the gauges? Can they be upgraded to a larger size?
The gauge is not too important, as they just carry signal voltage and not a lot of current. In fact, the replacement plugs have both wires the same size. 12 gauge stranded wire is sufficient.
Page 4 of the wiring upgrade gives you what you need.
Having tried the KnuKoncepts Ring Terminals, I found the Streetwires Power Rings to have a much better construction and work better electrically. Heavier gauge set screws.
http://www.amazon.com/StreetWires-PR.../dp/B000OQPZN2
For a really secure electrical connection, you can't do better than the Streetwires Inter-Lok Power Rings. Compression-type fitting, tightened with a wrench instead of set screws.
http://www.amazon.com/gp/product/B00...0ZBRXH01E2KYS5
Old 10-31-2011, 06:12 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Re: Altinator MOD.V4 Supplies?
You mean Alternator
1995 POLO LSI 76K MILES SOLD
Old 10-31-2011, 08:36 PM
Originally Posted by SVX92-97 View Post
You mean Alternator: rolleyes:
We know what he means.
Winter's coming... and Reading's coming soon after. I'm sure you have a lot better things to do than sitting around spell-checking posts.
Like fixing your idol problem. Or possibly getting it toad to OT's and letting him have a shot at it.
Old 10-31-2011, 09:38 PM
Old Fogey
You mean Alternator
Good point if one is doing a search, and that is the thread name.
Glenn
Old 10-31-2011, 09:25 PM
anyway i will work on my spelling but i would like to beat a dead horse on this altenator mod...
i plan in replacing postive post too.
here i posted on this before here. http://www.subaru-svx.net/forum/show...ttery+terminal
anyway when the mod is done i will have 3 cables connected to the postive battery terminal?
1. of them being the 4 gauge knukoncept wires coming from the altinator
2nd wire wire coming down from the fuse box? 3rd one
then the one that get runs from the wiring harness?
so my question is the one that comes from the harness goes to the middle of connector of the new battery terminal. I noticed that there is not a lot of wire there to play around with on the harness. then the other 2 wires where the bolts on the new postive post.
can i put power rings on the postive post one from the 4 gauge wire and the other on the one from the fuse box?
Old 11-01-2011, 02:28 AM
i plan in replacing postive battery clamp as well'
Here i posted on this before here post too.. http://www.subaru-svx.net/forum/show...ttery+terminal
When the mod is done i will have 3 cables connected to the positive battery terminal?
1st wire being the 4 gauge knukonceptz wire coming from the alternator through the MegaFuse
2nd wire is then the one that get runs from the wiring harness?
3rd wire goes to Fusebox.
I would not use the power rings to terminate the wires, but 4 gauge copper battery lugs instead.
The clamp is military-spec and is quite well-made and resists corrosion, Also made of Brass for marine environments
Add one wire to each side as shown or clamp 2 of them on the same side. This gives you a lot of versatility and flexibility to run multiple wires compactly where room is tight, I have used these before without problem/ Just keep all your main harness and fusebox connections on the side of the battery and only the single alternator wire attached to the top.
Available HERE
You can use separate locations to attach cables by using battery side mount screw-in terminals. Same electrical connection.
Old 11-01-2011, 05:02 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
I plan on redoing mine with those brass Battery lugs. I noticed my filed down power ring on the alt is already looking pretty nasty.
Old 11-01-2011, 10:32 AM
92 SVX 92 SVX is offline
here are some pics from my upgrade, I upgraded my cable that went to the starter as I did not like the corrosion and the state of that wire.
Now you will see that as of yet I do not have the mega fuse that is soon on my list.
A pulled back view to see everything.
The engine ground, you can see it a little in the previous pic too.
a few months ago my positive terminal broke and I needed something in a hurry this was the only one available at the store I went to, it works nice and for this application is perfect but its too expensive and overkill really.
As mentioned earlier I used some of the koncepts cable for starter cable here is a pic
And here is a pic of the connection at the alt, this is using a 1/4 battery lug connector so I did not need to file it down.
Old 11-01-2011, 11:05 AM
Chuckls's Avatar
Designated Asshole
Heres mine currently. I need to redo it.
The Charging post is looking gnarly..
