alarm questions
well, i went out last night and finally decided to tear the glove box out and check out why my alarm doesn't work. it was UNPLUGGED! after being a contortionist managed to plug it in and the led isn't working at all. i checked on it but it seems the connections are being made so i figure the led is dead. also, according to the owners manual, it won't auto lock the doors when you don't have a remote and it's supposed to honk the horn once when it arms. when mine arms i get no light flash or horn but my door locks unlock and then lock again and it's armed. it also says you have to lock it with the key but mine works by locking the doors and getting out like normal. it doesn't seem to work anything like in the manual. WTF? the shock sensor kinda sucks too. have to really hit the door hard to make the horn honk. oh yeah, it also says you'll hear clicking counting down when you get in. well mine flashes the lights and softly beeps the horn in a countdown pattern. it's so crazy! what does anyone know about this?
P.S. what's the little plastic white screw for on the module? adjust antenna or shock sensor? P.S.S. this is the 6000th thread in tchnical q&a!! Last edited by Budfreak; 09-14-2005 at 02:37 PM. |
Wtf!
well, i went to test the led on the alarm and was getting a solid 12 volts on one lead and a .5 volt pulse on the other terminal. the next thing i know i have no alarm! now i only get 1.5 volts on the one that had 12 and 0 on the other one. i could have possibly touched one of them to ground when testing but if that will kill the alarm then i guess i just figured out how to steal svx's. someone please help. i really need my alarm working so i don't lose the svx. i've tried disconnecting the battery for a minute and everything. HELP!
Did you check the fuse in the box? It's behind the small white plastic screw on the front of the unit.
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Well, I think your alarm is alive just that you didn't activate it.
From your description, it sounds like your keyless entry is ON but your alarm is not ON. How to turn on your Alarm? Very Easy!! Go and push your (security button) once!! It should be ON now. How to test it? Close your doors and press the remote.........you should hear the (beep). It could be the led inside the security button burn out but the security system itself is still working..... Let me know if my guess is right.
sorry my friend. way off. read my posts again. i don't have a remote for it and the alarm was functioning cause i tried it a million ways and the horn would honk and the lights would flash and so on. the led is obviously just burnt out. but thanks for trying anyway. |
so that's what the plastic little screw is?! that just makes my day in so many ways. i'm hoping that's the problem then cause i'm pretty sure i accidently touched the led lead in the security switch to a ground. was gonna go through all the fuses today but now i guess i won't have to. i'll post about what i find when i check it later. THANKS! |
The fuse cover only turns like 90 degrees to release. Hope that's the problem. Good luck!
Glenn
ok well that problem is solved at least.the fuse was blown so i replaced it and it's operating again.(still need a new led though) i noticed when it arms it unlocks and then locks the doors and gives a very small hardly noticable flick of the parking lights when it does so. my owners manual says it will not auto lock the doors when you don't have a remote, (which i don't)and it says it should honk the horn and flash the lights when it arms. why is mine different? anyone elses work like this? everything seems to work perfectly normal with it though in terms of protection. it goes off when i open the trunk and it flashes the lights and honks the horn in a countdown pattern if i don't put the key in quick enough. any experience here guys? i have lots of background in automotive security but it's hard to know if theres something wrong with something when you don't know how it was supposed to work in the first place. thanks guys, Jason
