Old 02-09-2005, 06:07 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Question DIY: alignment and wheel balancing
Just wondering have anyone of you tried done these two things by yourself?
I could find some articles for do-it-yourself on alignment but for wheel balancing it's kind of hard.
Is it easy, fun to try these?
Thanks,
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-09-2005, 08:39 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Thumbs up
If you don't mind risking a $400 or more set of tires go right ahead.
(That's why repair shops spend $40,000+ for alignment machines and tire balancers...)
Old 02-09-2005, 08:43 PM
lee lee is offline
could you provide a reference on the articles to look them over?
I could believe a DIY for toe-in, but DIY caster & camber - especially for a 4-wheel alignment - with +/- tolerances of about 0.5 degree, seems almost impossible...but then sure wouldn't be the first time I have done the stuck foot in mouth routine
Old 02-09-2005, 11:21 PM
mbtoloczko's Avatar
sans SVX
There is some equipment out there that the NASCAR guys use, but its expensive equipment. Much more than what you'd pay for a lifetime of wheel alignments.
Nothing out there for DIY wheel balancing.
Mychailo
Visit my locker
Old 02-10-2005, 06:08 AM
dcarrb dcarrb is offline
I've seen El Cheapo bubble-balance rigs in catalogs before (maybe Harbor Freight?), but, geez, man, proper high-speed balancing at most shops is a bargain. Why bother?
dcb
Old 02-11-2005, 02:19 AM
alignment can be done manually, but wheel balancing, not..
Old 02-12-2005, 09:41 AM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
the bubble level wheel balancer is only good for ~60 mph.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 02-13-2005, 08:49 AM
Beav's Avatar
Not as old as Randy
It can all be done at home, it is just a matter of accuracy. Heck, I can eyeball an alignment pretty close without any measuring tools, but if you want optimum life from a set of expensive tires....
There is obviously a reason why repair centers invest so heavily in balance and alignment equipment. How many alignments must a garage do to pay for a $40k alignment rack? Why spend the money if you can do it with a string and a stick? Gee, there must be a reason. C'mon people, get a clue.
Old 02-14-2005, 05:14 AM
you can't rely just on your naked eyes to make an alignment for your car, at least you need a measurement tape and a leveler... then the issue is probable...
Old 02-14-2005, 06:04 AM
Which makes it essentially good for nothing.
dcb
Old 02-14-2005, 09:28 AM
ssnsltd's Avatar
Good for nothing?
It makes a great paper weight.
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 02-15-2005, 12:02 PM
Earthworm's Avatar
Meow!
I've been using a bubble balancer for all my tires for the last 10 years (Justy + SVX). I've had my SVX to 145mph without shaking my fillings loose from poorly balanced tires.
Old 02-15-2005, 12:34 PM
mbtoloczko's Avatar
sans SVX
That's amazing. I wouldn't have thought it was that accurate.
Mychailo
Visit my locker
Old 02-15-2005, 02:52 PM
Earthworm's Avatar
Meow!
It's not going to be perfect but I've never had to re-balance any tire I've ever done.
Old 02-15-2005, 05:13 PM
oab_au oab_au is offline
A bubble balancer will only statically balance the wheel. Ok for bikes with narrow wheels. But with wide wheels they can be statically inbalance, but out of balance dynamicly.
Because the out of balance may be on the outside edge and the weights may be on the inside. When the wheel spins the two weight spots try to run in a straight line, causing a wobble, as each weighted spot trys to swing into the center line of the wheel. Which it can only do when it is at the front and back of the steering axis.
One Arm Bloke.
Tell it like it is!
