Ignitor Partial failure possible
My initial question is: Is it possible to have weak ignition module (ignitor)?
Now the background Been fighting a issue with my 92 SVX powered Vanagon. I have read just about every troubleshooting case on this forum and tried many fixes with no avail so I thought i would throw myself on the mercy of the group and see if anyone can think of anything I have missed. 1992 SVX (approx 150K miles) Symptoms
Current troubleshooting performed
Whats left?
Thanks for any help you can provide. I have the Stage 1 chip and the crush mod has been performed (did help with stumble) I love this engine when all is well! John Daron |
Greetings John, Thank you for going to much trouble in setting out an exact statement regarding your SVX, including symptoms and areas covered to date. It is seldom that this sort of effort is recorded. It is apparent that you have approached the problem in a very logical way. The igniter in effect comprises six solid state relays. The failure of a solid state switch is not usually intermittent and engine load should have no affect. It has not been reported here that the igniter is in any way a commonly faulty. However nothing can be taken for granted in this regard and one must depend on a logical approach. (5) When the TPS was replaced, did you set it properly by measuring the voltage output at closed throttle? Refer the how too section, or my locker for details. (6) Excellent that you have checked the AACV as few have done so. You rightly have doubts in some areas due to no fault codes being recorded, However I am sure that you appreciate that the system is not infallible. As a result all sensors must remain suspect. The outstanding item in your list is the air flow sensor (MAF). You report a possible rich mixture and improved running at low temperatures. Faulty sensing of the intake air flow could very well result in all the symptoms you describe. I respect and admire you for providing your complete identity. Sincerely, Trevor Sheffield.
Thanks for the help Trevor. I have a friend who lives about a hour away with a parts car. Seems like the next (cost effective) step is to visit him and try to swap some parts starting with the MAF sensor. I imagine thats not a cheap unit!
It also appears like the cam angle sensor has caused people "difficult to solve issues". That might be my next part to try after the MAF. thanks John Daron |
resolved
Old post but I wanted to let everyone know that replacing the MAF sensor fixed all my wierd problems. Thanks for the help.
John Daron |
It is very worthwhile when members report outcomes, as this adds valuable information the knowledge base. We struck the jackpot. However after all your work eliminating the many possibles it was not hard to pick the Joker. Cheers, Trevor.
I saw you had asked a question about the timing belt. Maybe it will help others who read this or maybe it will help you in the future. Yes, if the timing belt jumps a tooth or two on the passenger side pulley, it will run very strangely and no error codes will be reported. Glad to hear it was simply a faulty MAF sensor. Good luck
Tom |
