#76
Re: 11:1 CR Race/Street Engine build
Teaser pics. Sorry if they are out of focus... this is what happens when you let Eric touch the camera
Tom |
#77
Bill HRC 45 should be pretty good. Tom |
#78
Cool. High carbon steel it is (1095ish, if my memory serves me right). I'm guessing they may need to be heat treated after machining due to the heat imparted by the machining. We're basically talking about tool steel/knife blade material here.
-Bill
#79
Tom |
#80
You also need to show us pictures of the auxiliary water tappings...
Remember, always prove what you declare
#81
Danny have not tapped them yet. I am picking up the fittings and hose this week though
Tom |
#82
This will be interesting to see...
#83
I just found THIS source of shims also Tom. They are overseas though but priced good in my opinion. Shipping should be cheap...
#84
Tom,
I totally agree with you about the cross over pipe and its causing the left bank to not get enough cooling as we understand it that bank boils even when the radiator is running cool. The guy with the buggy still hasn't been able to keep it cool so we are going to cut the cross pipe today and raise the height. Happy to post photos when and give feed back to the degree of success or failure. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#85
after numerous emails and phone calls, I cannot find the proper size shims anywhere...
I had the thought of trimming down the valve stems to create a larger gap to use thicker shims. I would rather not do that in all honesty. SO.... I have ordered some Yamaha motorcycle shims. 25mm in diamter and 2.30mm in thickness. I will send these out to be cut down to the individual thicknesses they need to be.... Anyone else doing this... Highly suggest trying to take 1mm out of the base circle Tom |
#86
#87
Are you running into this trouble since you are using stock length EJ20 valves instead of the shortened EJ20 supertech valves used on the EFI logics car?
#88
He mentioned earlier he used Crower valves, I guess they are stock length.
EFILogics are 0.5mm shorter...
#89
yes reduce the bas circle.
Yes they are stock length valves Tom |
#90
A lot of engines are done like that. On Desmodromic Ducatis the shim top and bottom of the valve are usually rubbed down to size on an oil stone to suit. The only difference whether you do the shim or the valve, is the cost. We know which is cheaper. Harvey.
