Old 12-13-2018, 05:19 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Rpm cut off at 3,500rpm
I need help. I have a 5 speed swapped SVX, CEL isn't on, just rpm cut at 3,500rpm most of the time. Here's a video of it in neutral, does it in all gear though (really jarring in gear of course)
https://youtu.be/KBmwa2EbwaY
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 12-14-2018, 01:44 PM
sd2649's Avatar
Driving in Style
Re: Rpm cut off at 3,500rpm
Where does anyone go for help with the SVX these days? This is so sad compared to how this forum used to be back when I first joined...
-Steven
SOLD
Old 12-14-2018, 04:40 PM
I agree with you 100%.
Old 12-14-2018, 07:12 PM
svxnavyvet svxnavyvet is offline
looks like rev limiter limp mode but no check engine light?
Old 12-14-2018, 07:32 PM
oab_au oab_au is online now
How long has it been doing it?
How long ago was it converted to 5 speed?
One Arm Bloke.
Tell it like it is!
Old 12-14-2018, 08:43 PM
sd2649's Avatar
Driving in Style
Just the past 2 days. A month ago.
I have saved CELs for both O2 sensors, but nothing current. If somehow both O2 sensors were out, would it run right or cause this?
-Steven
SOLD
Old 12-14-2018, 08:54 PM
I can't think of anything that would cause it sorry, but I have seen some 5 speed conversions where the wiring was altered that caused some problems. Did you run any extra wiring, or jump any connections?
One Arm Bloke.
Tell it like it is!
Old 12-14-2018, 11:32 PM
sd2649's Avatar
Driving in Style
I didn't do the swap. I'm asking the mechanic now.
-Steven
SOLD
Old 12-15-2018, 01:19 AM
This is one of the problems that a conversion had.
www.subaru-svx.net/forum/showthread.php?t=60412
One Arm Bloke.
Tell it like it is!
Old 12-15-2018, 08:39 PM
Trevor's Avatar
Trevor Trevor is offline
It does not appear that the transmission or its connections are involved with the tacho.
The taco utilises a signal from the ECU, which apparently uses the crank position sensor or the engine timing circuitry in order to detect engine speed.
The tacho derives its ground and battery voltage supply via a two pin plug-socket connected by a black ground wire and a green yellow positive supply wire, supplied via fuse 15. From the available diagrams it appears to exit the instrument loom and is under the dash.
Worth a check for voltage and ground.
Trevor, New Zealand.
Old 12-15-2018, 08:46 PM
sd2649's Avatar
Driving in Style
Fixed it. Loose ground terminal on the intake manifold. Back passenger side. I figured it was a ground issue when my speedo started cutting out too.
-Steven
SOLD
Old 12-15-2018, 10:43 PM
The engine movement must have been moving it on and off.
That was an easy fix.
One Arm Bloke.
Tell it like it is!
Old 12-16-2018, 12:19 AM
Trevor's Avatar
Good one, my analysis was spot on.
Old 12-17-2018, 02:24 PM
sd2649's Avatar
Driving in Style
Absolutely, I had nightmares this wouldn't ever go away...
-Steven
SOLD
Old 12-17-2018, 02:25 PM
sd2649's Avatar
Driving in Style
Spot on analysis! I had the intake manifold off a week ago to replace all the cracking vacuum lines and PCV system. I finger tightened that bolt and forgot about it as the car was running perfect. I guess it wiggled loose.
-Steven
SOLD
