What do you think is necessary for 500HP
What fuel system mods
What compression ratio What boost level and Any other mods needed |
First step
Is to get a new engine. I know that Paeco does that, and some company that starts with an R (I think?) Paeco's stage II is reated at 306bhp...after that, basics like a header, downpipe, cat, exhaust, cold air intake, and *maybe* a turbo. I figure you could twin turbo the SVX and mount an intercooler if you got the CF hood (since it has the scoop, there may be room for the intercooler) - But it would be better to ask some of the more knowledgable guys
I know JCS is developing a Super charger for an svx and no hood mods would have to be done. Contact them for more details, if you need the number then check out "Mods Update" thread.
Later Chris |
I already have a turbocharger on my SVX. I thought paeco just built N/A EG33's
Just because
Paeco only builds NA's, it doesn't mean you can't drop a turbo on it after the fact
Re: First step
On a second note, why stop at twin turbo. Why not go all the way and for quad turbo's. However do the dual stage turbo setup. A small T2 turbo to provide low rpm boost, and switch to a T4+ on the higher rpms to gain the HUGE power. I figure, new cam, crank, rods, pistons, oversized valves, upped injectors, bigger fuel pump, a complete replacement of the current ignition system, intake, and exhaust, will more than get you there. But you still have to remember we are talking more than double the current hp....that is quite the leap. Ryan
92 LS-L Claret / Black UR Underdrive Pulley, Bosche Platinum +4 Plugs, K&N Cone Filter http://www.ryanmacdonald.com http://www.digitalvertigo.net http://www.open-innovations.com |
Who needs
a Lamborghini which only gets 12mpg when you can have a 600bhp SVX with 24mpg?
Has anyone ever thought of using 2.5 rods and pistons and having a custom crank made to give the H-6 3.8 liters of displacement. A large single turbo will give the most power. Maybe some bigger cams stiffer valve springs 7500-8000 RPm redline. 8.0-1 or 8.5-1 compression ratio 15-20psi of boost large intercooler. Tec II engine management.
One large turbo is good, but creates that much more lag. It depends what you want...raw power or off the line tear it up. A big turbo won't spool up until 4000+ rpm's...but like you said would make the most power. I personally like the twin turbo idea. Keep the compression down to 8.5:1 and run 18psi to a 3 cyl bank....now you are talking some big power.
Ryan
Re: Who needs
Re: Re: Who needs
Where've you been hiding out Suby_qa? Say howdy to Pat for me too!
Pull my finger! |
Re: Re: Re: Who needs
I think Pepe got so scared that he must've pepe'd in his pants.
But I think he re-incarnated into this club as "SVX Master Tech", and after his first post, which smelled like a rat, I privately notified Aredub, and he notified Chris. Whether he disappeared on his own, or had help disappearing from this club courtesy of Chris, I'm not sure. VK |
Re: Re: Re: Re: Who needs
Pull my finger! |
I spoke with Paeco
The rebuild they do is pretty standard strenthening porting etc. too much to mention here. Very solid base though. They sound very good. When I questioned their fuel delivery they told me they use carborators. UGGGGG. Anyway that is no big deal. You can rebuild the engine with nismo fuel injectors which will support up to 500 HP (555 cc/min). Lower the compression to 8.5:1. New fuel pump and line modifications to support more fuel. I would go with a much larger oversized fuel pump in order to cool the rail. Kevin you need to call me sometime. PM me with your number and we can talk some mods.
Chuck
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
