Old 04-03-2017, 03:50 PM
WTB Instrument Cluster
Tach isn't working, hoping replacement with a functioning instrument cluster is the answer.
Old 04-04-2017, 04:06 AM
92 SVX 92 SVX is offline
Re: WTB Instrument Cluster
You can replace just the tach in the cluster, if you want. I wish I had a cluster witht a working tach, but my extra I took out because the tach was acting strange, it was showing idle of 1200 to 1800, even though the engine was 600rpm, and when reved it would stop at 5k or so instead of showing the revs higher
Old 04-04-2017, 05:03 AM
I have a working gauge cluster in my parts car. I didn't mention it because the speedo is in km/hr. If the tach and speedo can be separated easily it will work for you.
The car is still buried in a small glacier of snow but it will be raining heavily here for the next 3 days, so it should melt quickly.
Old 04-04-2017, 08:55 AM
ok, im interested. id imagine there will be some soldering involved, no? ive read that the stepper motors may be the culprit for what im experiencing.
Old 04-04-2017, 09:01 AM
no soldering, you would need to unclip the plastic cover, then unclip the black plastic from the white plastic remove a few screws that hold a circuit strip from the black to the white, then you have access to all the gauge modules, unscrew 3 screws that hold the tach to the main cluster and it drops right out, put the new one in and screw in the screws and snap the black to the white etc etc, reverse of remove
I can take some pictures if it will help?
Old 04-04-2017, 10:03 AM
Ok I see what you're saying. But let's think about this. Replacing the tach itself would imply that it is somehow getting stuck or is bent preventing its full range of motion right? I don't know that replacing the tachometer alone would fix the issue...
Given the situation described earlier, that does not seem to be the case. It's either an electrical connection between the ECU and the cluster gauge or the tach stepper motor itself.
Now I could be completely wrong, just talking out loud at this point.
