Altenator voltage dropping at idle?
I have a '92 SVX with 260K on it and we are having a problem that I have heard other SVX owners have also experienced. I was wondering if anyone has a solution for this problem...
The altenator seems to charge just fine (14v) when the engine is running above 1000rpm's (normal driving). However, when the car is idling (700-800 rpm) the charging voltage drops down to around 11volts. If the car is left idling too long or the battery is old and it is very cold out (Canada eh)... the car will konk out. I have talked to the dealer and they know about this problem on older SVX's even with new Subaru rebuilt altenator's. But they don't know the solution. Has anyone ever experienced this and found a solution? Let me know. Thanks, |
Where are you reading the voltage from?
Thanks for the quick responses guys.
First, regarding the possibility of a bad cell, it is possible, but unlikely as a month or two ago we replaced the battery. Although, it could have had a big load running on it... not sure. The 11v could mean 11.9 volts, as it was the dealer that ran an AVR test on the altenator and the service guy said that it had less then 12 volts at idle, he didn't give me the exact number. I would imagine during an AVR test, they don't have a huge load on the system? Not sure, never seen one run before! |
Get one of those volt met... darn it!
I have this exact problem and depending on what's on or off voltage fluctuate at idle between 13 and 11v. I made a thread about it that noone responded to.
