Old 08-30-2005, 07:43 AM
GreenMarine's Avatar
From POST-***** to LURKER
Here are the ones that are whe weirdest of all.... My brake cable snapped clear through.... When I repped the consol off (cause there was smoke coming from underneath it)... I found the brake cable glowing!!! and it had snapped!!!
Thanks guys!!! This is all I can get this morning without really ripping anything off.... I appreciate any help I can get.... Thanks again
Old 08-30-2005, 07:58 AM
Sorry I won't be around to answer questions guys... I have work till 3:30pm.... Talk to youguys then!!!
Old 08-30-2005, 08:27 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chris,
I'd start by disconnecting the ground wire up by the battery and cleaning it up before screwing it back down. Then I'd move to the area of the fire and peel back the wire loom around the wires in that area to see if some of the wires within the looms haven't melted together.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-30-2005, 10:00 AM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
You are in luck my friend. ...well hopefully.
That ground that connects the battery to the chassis is the only ground in the SVX that connects directly to the chassis. The larger wire goes to the starter mount and there are various grounds that connect the engine/trans/exhaust to the chassis.
But that main ground is shot - change the entire thing and make it thicker. Also clean away all that black mess around it. The parking brake cable is not weird at all. Reason being is that is a hell of a good ground when the main one fails. All the electronics were then using that parking brake cable as ground point hence causing it to get hot.
Try changing that battery -> chassis ground and give it a go. Good luck.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 08-30-2005, 10:02 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally Posted by GreenMarineSVX
Pistures coming within the hour....
Are "Pistures" photographs you take when you're Pissed?
Randy Johnson
Mike Davis -- at Reading VI
Old 08-30-2005, 01:54 PM
Probably
Thanks for having a sense of humor about it Randy
Old 08-30-2005, 02:07 PM
Thanks Mate!!! Awesome advice.... I'm gonna do it now before I have to go to class and give it a shot!!! I'll post back with the results
Old 08-30-2005, 02:47 PM
Alright, well I got in there... Took the battery out, cleaned the terminals... Took out that bad (burnt out ground).... Just happen to have an extra wire to use to make a ground.... I am off to get a set of pliers at the moment though... Then I head to class, I'll be back around 8pm tonight... I may go out there and work on it a bit tonight just because I am feeling very optomistic about it and really hoping that this will be the end of my worries.... I'll let everyone know!!!
Old 08-30-2005, 02:53 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Good luck Chris. I'll keep my fingers crossed for ya!
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-30-2005, 03:11 PM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
I sure hope that works, but I don't think that is your problem. My 95 runs fine with that ground wire completely detached.
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 08-30-2005, 06:12 PM
Well, I've got alot of homework tonight... So if I get out there and work on it, it will be alittle later on tonight... I'll keep everyone posted though!!
Old 08-30-2005, 07:03 PM
rmjjensen's Avatar
cool. You never know - changing the ground is just a good place to start. But there is evidence it is bad because your parking brake cable got hot from flowing electricity.
Also check any melted wires and seperate them if they're fused together ....replace any that are really bad.
Old 08-30-2005, 07:58 PM
Subafreak's Avatar
Superbeast
Well I'm assuming possiblythat the E-brake cable rubbed thrue a radio power cable? Or am I seeing things that arn't there?
Old 08-30-2005, 08:28 PM
That could be true too man... I'll be chacking it all when I take as much stuff out of the interior as possible... I'll definitly post what I find... Thanks for the suggestion though!!
Old 08-30-2005, 08:37 PM
No engine ground?
This hasn't been an ordinary short. There has been at least 150 amps flowing there. I have seen this type of short when the main ground to the engine has been disconnected. The starter draws about 250 amps, this current has to get back to the negitive pole of the battery, if the main ground lead that runs from the negitive terminal to the engine block doesn't provide the path, every metal connection between the engine block and the body will have to carry it. That leaves the small ground from the body to the negitive side of the battery to carry the current, so it burnt up.
Thats why the hand brake cable, the clutch pipe, throttle cable, and all the small ground wires that run from the engine to the body get overheated. I think the shorting will only be in the ground wires, like the one that runs from the back of the engine to the firewall, ect. Maybe it won't be too bad Chris.
Harvey. (won't let me post smiles)
