Old 09-26-2005, 11:50 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
rotational inertia....rotational inertia......
Compare the weight of the STI rims + tires to your old set up....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-26-2005, 12:24 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
-Bill
Interesting. I dyno'd my car with my stock wheels and all season Bridgestones last December. Each wheel and tire combo weighed in at 47lbs a piece!
My new RX-7/Dunlop SP Sport combo weighs in at a tad under 40 lbs.
Hmmm.....
-Chike
2006 Steel Gray WRX TR (sold)
Old 09-26-2005, 12:30 PM
svxsubaru1's Avatar
svxsubaru1 svxsubaru1 is offline
Originally Posted by Chiketkd
Correct. Based on Mychailo's dyno results with his Mr Dyno, doing a 5/6mt conversion typically gives you about 175-180hp at the wheels due to the lower driveline loss.
The phenolic spacers, custom headers-back exhaust and Impreza fpr have caused my traps to increase from 89.5mph to almost 91.3mph...
-Chike
The highest ive traped was 93MPH .
92 Honda CBR 600
95 Miata
Old 09-26-2005, 12:35 PM
Chiketkd's Avatar
You do have a 5spd though from what I remember from talking to you on NASIOC. What was your best 1/4 mile, btw? n/a or nos?
One 5MT member here, PhastSVX, trapped at 95mph during an n/a 14.59 1/4 mile run.
-Chike
Old 09-26-2005, 12:40 PM
hey Chike, do u think I will be able to lay down trap speeds over 100mph when I finish the twin turbo?? My car will remain completely in street trim as I love the sleeepers so it will still be heavy. I hope once I am done to be able to tag mid 13's maybe even scrape into the 12's
Old 09-26-2005, 12:46 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
Still, 249hp is within 4hp of what a Cobb Stage 1 STI makes!
If your engine was truly making 250hp at the crank on a 80 degree day, you should be trapping around 91.5+mph in the 1/4 mile and probably running 15 flat to upper 14's in the 1/4 mile.
What mods have you done since you ran the 15.37 @ 89.6mph? Is your car still in the same state of tune?
-Chike
how about 95.00 granted my car weighs in atleast 100lbs, and less then rediculous(auto subaru) drivetrain loss :/
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 09-26-2005, 12:48 PM
Chiketkd's Avatar
I think you said you planned on running 6psi of boost initially? Doing the calculations:
6/14.7 X 230hp = 93.87hp above stock output, or ~320+hp (assuming a perfect turbo system with no boost leaks, etc.)
A drag racers *rough* rule-of-thumb is every 10hp increase = gain of 1mph in the 1/4 mile. You should therefore gain 8-9mph in your trap speed which will put you at 99.5-100.5mph in trap speed.
*Understand that this is no more than conjecture as the drag racer's rule-of-thumb is far from being scientific!
-Chike
Old 09-26-2005, 01:31 PM
in that case, I feel that I am going to be maxing out the injectors below 6lbs. I planned on racing at 8psi so that would put me even higher than that. I think i need to get the system operational and work from there to cure my fuel issues. I think maybe upgrading to some bigger injectors like LAN will be including in the stage 3 package and running an E-manage like SVXtasy has in his car. I still am going to need a co-driver if I cannot find some time on a dyno to tune it. I may dyno the car with the N/A stage 2 but I will definately dyno it with the twin turbo just for bragging rights
Old 09-26-2005, 02:36 PM
Chiketkd's Avatar
The stock injectors were flow tested to 60 psi with no issues. Even with an adjustable fuel pressure regulator and the Walbro fuel pump, will you really max out your injectors???
-Chike
Old 09-26-2005, 03:53 PM
mbtoloczko's Avatar
sans SVX
-Chike
You can find a downloadable (Windows excuteable) calculator on this website which will give you an idea of what flow rate is needed:
http://www.ricdidonato.com/Downtime/mods.htm
Mychailo
Visit my locker
Old 09-26-2005, 04:11 PM
Chiketkd's Avatar
Thanks Mychailo. That's a good calculator to have!
Old 09-26-2005, 04:15 PM
Earthworm's Avatar
Meow!
Link didn't work for me. This one did though:
http://www.ricdidonato.com/Downtime/mods.html
(.HTML...not .HTM)
Old 09-26-2005, 04:43 PM
Chiketkd's Avatar
(.HTML...not .HTM)
When it first didn't work for me, I also added the 'L'
-Chike
