Tacho strange behaviour
Some 12 months ago my tacho started registering to max just over 2K as if its total scale of movement got limited to just over 2K. I didn't feel like ripping out the instrument cluster from the dash to check things out. Some 3 months ago, for no reason at all I noticed that it was again working correctly. Well, now all of a sudden it stopped working completely!!
Anyone with any experiences with their tachos? Sounds like it may have been a loose connection which came good and now is broken completely. Any advice will be welcome. |
Re: Tacho strange behaviour
In all my years with SVXes never heard of a tach problem. Check your rpm sending unit.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
I can't help in diagnosing the problem but, did experience the same. The tachometer struggled to reach 2000 rpm and stopped there. At the time, I found a replacement gauge cluster and swapped it out. The replacement tach still works fine, 3 years later. On the old gauge cluster, I could not visually see and breaks in the wire connections or circuit board.
Are you sure the needle is not rubbing the face? The needle is very sensitive to pressure....
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
