Re: JDM TCU Wanted
Wow, that looks unusual - anyone else got the english equiv. (and what does it mean?).
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: JDM TCU Wanted
I have fixed my TCU (Damaged track caused by a modification I was doing), so the pressure is off finding one. Daniel |
Re: JDM TCU Wanted
The kana says "sentaa difurakku".
So most likely center differential lock is what it means.
-Ash 96 Polo Green - Daily Driver 92 Teal Green - Restoration in progress |
Re: JDM TCU Wanted
Confirmed by checking my NZ instrument cluster.
It says Diff Lock in the same location. |
Re: JDM TCU Wanted
Shane,
are you trying to do a switch in order to get diff lock working when you want manually ?. It would be interesting to know what the wiring would be in order to do that.
