RWD conversion
Is there any way to makes an svx RWD only?
Re: RWD conversion
Yes, Huck brought his RWD SVX to Reading this year.
Re: RWD conversion
Is it a very difficult process, or just a matter of disconnecting axles in the front lol
Re: RWD conversion
It is a lot more involved than just removing the front axles. In fact, you have to leave the front axles in since they keep fluid from leaking out of the trans, as well as hold your front wheel bearings together. What is involved is taking apart the back of the trans, grinding off one side of the transfer clutch gears, and using pins to lock the clutch all the time.
MY TOYS 95 SVX 98 Lincoln MarkVIII LSC, 5-speed swap 91 Marcury Cougar, 393" stroker, completely insane! 89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt. 80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished. |
Re: RWD conversion
Since the transmission normally outputs a maximum of 50% traction coefficient to the rear wheels on an occasionnal basis, is the rear drivetrain strong enough to push the car around at 100% capacity and be driven everyday?
Re: RWD conversion
I suppose there isn't a standard RWD transmission that fits the bill...
I like AWD, but I have wondered if there is a manual, or similar automatic that runs in a RWD-only car, that would fit with a longer driveshaft. I also wonder if axle stubs could then be used to hold the front hubs together, without the axle shafts... I'd be plenty happy with an AWD Manual Gearbox swap in an SVX, though, myself. |
Re: RWD conversion
So, If you could find some way to really beef up that rear diff, and keep the fluid cool, you might be able to run an SVX as a RWD for an extended period of time. I've thought about it too
