thunking noise when going into reverse
just like the title says. i hear a thunking noise all most everytime that i shift into reverse. from both park and neutral. please let me know what you guys think.
Check the bushings that support the rear differential. There are two of them located between the diff and the muffler. Both of mine were torn to pieces and I could move the diff around easily. If I was at home I'd post pictures, but I'm at work so pics will have to wait.
I had thought it was the transmission support that was damaged, and as it was being replaced, I noticed those bushings were bad too. Replacing the the tranny support solved some of the clunking, but it was in much better shape than the rear bushings, and a few days later when those came in and got replaced the clunking was eliminated completely.
Shane 92 SVX - Sold 98 BMW M3 Sedan 89 Honda CRX Si w/B16 swap 91 Honda CRX Si |
Pictures would be greatly appreciated.
I get that clunk when going from reverse in to drive.
Your telling me that my bottle of soda has more displacement then your honda O_O -1992 Pearl White Subaru SVX -1995 Briliant Black Mazda Precidia (sold :'( ) -1996 GMC Sonoma ZQ8 pickup http://www.subaru-svx.net/photos/fil...-TL-/20502.jpg -Taras |
reverse thunk
For shock going from N to R, the ATSG troubleshooting chart suggests the following in order of most likely culprit;
Valve sticking Faulty 4A accumulator Deterioration of ATF. I think the first two are located in the pan and would not require pulling the tranny to have your transmission specialist cure the problem. Joe [As above, bad support bushes does also create this problem]
forward thunk...
Again, the troubleshooting chart suggests the following in order of most likely....
Deterioration of ATF Faulty N-D accumulator Valve sticking Faulty TCU Again, the two middle ones are in the cassette in the oil pan, and more easily fixable by somone who knows what they are doing. Joe
Might not be tranny
Even though it is probably transmission-related, make sure you check out your cv axles. A faulty outer joint would cause a similar clunking noise to the one you are describing.
Collin 1995 L AWD Locker 1987 Porsche 944 turbo 80k miles. MBC + Chips. Relatively Stock |
Here's a picture of the bushings, as promised:
Do you happen to have the part numbers for those Differential Bushings?
I was under the impression that those bushings were an integral part of the differential mounting subframe, and therefore not replaceable. Jason.
1992 Charcoal Grey SVX - 165,000km 1992 Ruby Red SVX - 165,000km ....now with sequential VIN numbers! 1986 Holden (Isuzu) Piazza Turbo - 225,000km 1993 Mercedes W140 S500 Coupe - 153,000km 1990 Mercedes W124 300D - 313,000km EG33 + 4EAT + VTD AWD = SVX |
They aren't listed as a replacement part on 92's but seem to be on 94's
