Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Turbo Projects
Old 07-31-2009, 03:19 PM
Giugiaro Giugiaro is offline
boostin to the outer space
My Super Build
Hello all,
I would like to announce my super build for the SVX. By super build I mean everything from the ground up:
- Suspension/Braking
- Engine refurb with brand new components including a crankshaft.
- Engine boost with extremely high numbers.
- Classy wide body with bodykit.
- New body parts including glass.
- Sound system and more....
Summary: everything has been bought so far still finalizing some few engine components. Nothing has been compromised in terms of quality and parts. Everything related to rubber seals will all be replaced. Hardware everything brand new, only turbos have 5k each.
The car will be done on two phases:
1- Engine/Transmission/Suspension/Braking/Sound System. Parts are already there, the precise custom fabbing will be completed year 2010.
2- Wide body with body kit, new glass and seals, custom made kit... Completion year 2011.
Goals? Very very high hp figures. Will be the most spectacular/fastest SVX ever.
Pictures of some of the parts: http://s819.photobucket.com/albums/zz116/GiugiaroSVX/
The SVX expansion goes two ways:
1. Horizontal expansion: Multi SVXi
2. Vertical expansion: Fun max from one SVX
Old 07-31-2009, 03:55 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: My Super Build
Holy Crap! Did you rob a bank?
Wanted: Steering Wheel
Old 07-31-2009, 05:29 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Re: My Super Build
Wow...it's gonna suck driving a multiplate Tilton clutch on the street with such a heavy car. But it'll definitely hold some power, just doesn't tolerate any stop-and-go and it's a be-yotch starting on hills (not much inertia to speak of).
You've certainly been out spending money!
Bob Légère
EG33 Impreza tweaks
Old 07-31-2009, 07:06 PM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
Re: My Super Build
NICE! Subscribed. What are you doing body wise exactly? I plan on developing stuff in a year when i move to Cali and will be aprenticing fabrication work and stuff. I want to drop like 600lbs today through body work and other things here and there. Develop aero parts and OEM spec +widebody spec that match the lines already present.
-Gaddis
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 08-01-2009, 03:38 AM
/subscribe
Old 08-01-2009, 05:27 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Re: My Super Build
/subscribe
Me too
What are your plans for the engine?
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 08-04-2009, 01:28 PM
Re: My Super Build
Michael, yes. well almost. I didn't put any upper figure for my build. I budgeted 300$ a month over three years and ended up averaging 550$ instead... so far. I don't want to mess up.
Rallybob, yes the tilton is going to be a challenge. But this car will not be driven in a... normal way
Plans for the body, a hibrid between the 89 prototype rear fenders and something of my own design.
Plans for the engine, as I've stated, very very high numbers
Please understand that I am still in the stage of gathering parts for the buildup. No real progress has been achieved on the car yet.
Old 08-04-2009, 06:30 PM
the_paynter the_paynter is offline
Re: My Super Build
Are you using two TD04 turbos? Thats just what they looks like, I could be wrong. If so it will spool VERY fast and be a blast to drive
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill.
1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback
Old 08-18-2009, 05:42 AM
Re: My Super Build
yes, they are two TD04L's. Well it is going to be a blast indeed!
WRX: one TD04 for 4 cylinders.
SVX: one TD04 for each 3 cylinders you do the math.
and I also added few more pictures of the brand new ignition coils and window regulators.
Old 08-18-2009, 09:30 PM
oab_au oab_au is offline
Re: My Super Build
WRX: one TD04 turbine powered by 4 cylinders.
SVX: one TD04 turbine powered by 3 cylinders you do the math.
One Arm Bloke.
Tell it like it is!
Old 08-19-2009, 01:37 AM
Re: My Super Build
Sorry let me rephrase:
WRX: one TD04 turbine powered by 4 untuned cylinders.
SVX: one TD04 turbine powered by 3 cylinders with super-tuned valvetrain timing/lift
Old 08-19-2009, 10:12 AM
RallyBob's Avatar
Re: My Super Build
So are you looking to basically max out the TD04's then? You'd be lucky to get 550-560 whp with them, and even then the boost levels required to make 280 whp per TD04 create a LOT of heat thanks to inefficiency at that psi (18-19 psi). Make sure the cooling system is appropriately modified and the intercooler is massive...you'll need it!
I think the turbos will be holding you back big-time, at least compared to the rest of the buildup. No reason doing much in the way of cams and headwork IMO, the turbos won't breathe well at higher rpms anyway. Now maybe a pair of GT28RS's or GT2871's....
Bob Légère
EG33 Impreza tweaks
Old 08-19-2009, 11:41 AM
Nevin's Avatar
Nevin Nevin is offline
Re: My Super Build
Looks to be an impressive build. Keep it up!
Question though: Why would you go for td04's? That's a pretty small turbo for a high horsepower goal such as you claim. You could probably do twin gt3071's for huge power, or something like that. Twin gt2860rs turbos would do an excellent job and have sweet spoolup.
Not bashing, but I'm just curious why you picked them!
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 08-19-2009, 02:10 PM
Re: My Super Build
i am not looking to max the turbos rather rely more on the valvetrain mod and less on them. I am planning to go up to 550hp rather than 550whp with those turbos.
i originally wanted to do a turbo build with a smaller budget but then thought to wait a bit more time and do it right without sacrificing quality which is a priority.
so i will start with a solid base structure and then the peripherals can be upgraded later on. by solid structure i mean eliminating the word "i could have..." which equals all the best engine components. so the big bux goes to the valvetrain with the highest lift and solid internals like the pistons, new crankshaft, rods, arp's, etc.
and a 6 speed is a must here, and you know its limitations. hence bounding myself for now with 550hp with a couple of low mileage 100$ turbos
RA gears and larger turbos can go next if 550hps are not sufficient
for cooling, water to air will be installed, already bought. i read somewhere on this forum that the internal block has heat traps, which worries me the most and i need to pinpoint it for the project to move on.
Old 08-19-2009, 02:26 PM
Re: My Super Build
I was looking into a pair of EVO III 16G turbos for my SVX originally but I decided to go with one big one. Right now i have a garrett 60-1 and I will be putting on a new Billet Percision turbo over the winter once I get mt hands on a hydra and some internals.
