Accepted to grad school! Summer plans
So, there's now a week left in my last semester before graduating with a bachelors in biomedical sciences. One final exam and one research paper, and I'm done. Well sort of. I just found out I got officially accepted to a graduate program about a week ago. I'll be coming back in August to start grad school at the same school, in the same research lab where I've been volunteering for the past year, to start working toward a PhD in Organic Chemistry. Needless to say, the wife and I are super excited.
So, seeing as how the next 4 years are going to busy with research, I've put together a little list of all of the car projects I want to get finished with over the summer: SVX: 6-speed swap -clutch/flywheel/pressure plate have been resurfaced. found out it's a ~2600 lb pressure plate and got a stage 1 clutch. poly bushings konis/dayle's springs -changed my mind, G/C coilovers instead, which have also arrived brake fluid/pads - done (Redstuff pads f/r and superblue) plugs stebro exhaust wheel bearings maybe some interior work apkarian's LED tails The majority of these parts are sitting in my garage, ready to go as soon as I get a chance. Also be helping to get my brother's 240 put back together now that the motor's built and together: 240: put engine back in -done change ecu to SR20DE ecu -wiring harness about halfway hooked up wire-in boost controller and ecu piggyback trunk-mounted battery -all the wiring is done, gotta mount the battery itself Update: We just discovered the hood doesn't shut all the way. Gotta figure something out, but most likely it'll end up looking like tom's beast. What do y'all think? Any other miscellaneous maintenance I should do while I have the car all apart? I need to order some valve cover gaskets and cam seals to do those as well, anything else I should reseal while I'm at it? I could also really use some general advice on the 6-speed swap. I'll post pics of all the parts I've got for it later.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 07-04-2010 at 09:52 PM. |
Re: Accepted to grad school! Summer plans
You are a crazy man. but good luck. I think you are going to be busy.
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
check the rear trailing arm bushings and rear diff bushings. You will have it apart anyway so may as well replace those too.
My rear diff bushings were all but destroyed! I'll second that!
Trailing arm bushings are part of the strongflex (polish) bushings (correct?), and new rear diff mounts are sitting in a box next to the 6-speed I really wanted to get some of the poly ones from earthworm, but I think he stopped making them or something.
Stock sti shiftknob w/cobb shortshifter: The strongflex bushings: The car it's all going into:
really clean SVX I'd love to help you out in the future gettin that baby turboed! It'll look nice with those LED tails you just bought
Yea couldn't resist. First post updated.
Better work fast, summer daze won't last
Yea seriously. Gotta get the 240 running first before any real work can begin. Can't have 2 cars down like that.
Redstuff pads will stop that thing on a dime, I have them on the fronts and hawks in the rear.
Yea they do feel better than whatever ones were on there. Actually I got them based on an old post of yours thanks
Update: Well, I decided not to attempt the 6-speed swap myself and have most everything done at a place called S&R here in Tampa. Hopefully it doesn't cost too much, but I figure best to let them at it than do it myself and have something go wrong.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 06-10-2010 at 12:13 AM. |
Save your money you'd spend in labor for more mods |
