Old 09-20-2007, 01:03 PM
to make the 4.11 rear bolt up you either need to swap rear diff carriers OR get another left side axle (no extension). This will eliminate your LSD though
I say stick with a wrx trans... You will need to buy the following to use that trans.
- Clutch fork and boot
- Clutch kit
- Flywheel (yea they are different)
- Hydroulic clutch slave cylinder
- Rear differential
Buying all of those parts is probobly gonna cost more than just getting a wrx tranny
Old 11-01-2007, 08:53 AM
AlcyoneDaze's Avatar
<-- custom hood ornament
Instead of starting a new topic, i'm going to resurrect this one.
My transmission is in its death throes now, heavy slippage between 2nd and 3rd, and 3rd and 4th - so im just waiting for it to go.
My options are to either get an ebay SVX trans as a temporary fix, or upgrade to a 4.11 or 4.44. It was mentioned the 02-05 WRX trans bolts up to the same rear diff as the SVX, can I use an auto WRX transmission with 3.90 gears for this?
I'm not too mechanically inclined, but I'm not an idiot and have done all work on my car in the past year (except wheel bearings), and am wondering if this is something I can do myself or should I just pay a trans shop?
any help appreciated, my car is still running and its gotta stay that way if I want to stay employed... thanks!
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 11-01-2007, 09:05 AM
If you can't go without the car for more than two days, I'd suggest either sticking with a stock swap or farming it out to Tom for a 5 spd swap.
Depending on your trans swapping experience, you can even safely do an auto 4.11/4.44 over a weekend.
Old 11-01-2007, 09:21 AM
Unfortunatly a 5mt is not in my future right now, my total budget is under $1000. I'm looking at a rebuilt 4HEAT transmission on ebay, and will probably have a local shop install it.
http://cgi.ebay.com/ebaymotors/1992-...QQcmdZViewItem
If your not busy Hocrest... wanna make a few bucks?
Old 11-01-2007, 10:27 AM
now I'm torn between the stock and doing a 4.11 swap...
does it matter if I use a JDM transmission, im seeing more of them on ebay than usdm
Old 11-01-2007, 10:44 AM
Here is one a little closer.
4.44
Both Eric and Mike have used this company and are happy with them.
Old 11-01-2007, 10:49 AM
awesome, paterson is less than 45 away from me! I know I have this question cooking in both forums, but it surely won't be a problem if I go with a JDM trans? I know Im being a pain but I want to have the new trans and diff in my trunk and ready to go by the time my current one craps out
Old 11-01-2007, 11:49 AM
wow, nobody on NAISOC knows either...
Old 11-01-2007, 01:04 PM
those trannies are fine... As long as you don't get your hands on a VTD jdm trans somehow it should work
Old 11-01-2007, 01:14 PM
THANK YOU!
I've been reloading this thread for the past several hours waiting for an answer. theres an EJ25 rear diff waiting for me at the junkyard, and I'm going to go ahead and pick this trans up in Paterson.
At the risk of getting flamed: is it okay to do neutral drops and other foolery to kill off my 4EAT? I think I recall hearing that you can destroy a transmission without hurting much of anything else...
Old 11-01-2007, 02:19 PM
how would you transport it to it's shop?? Keep the auto running as long as you can
Old 11-01-2007, 07:22 PM
Is it out of a manual or an auto? a manual will be a 4.11, the auto is 4.44
On the top of the case there will be some letters stenciled. 4.11 is "T2", 4.44 is "TP"
Old 11-01-2007, 07:34 PM
I am pretty sure I have an extra 4.44 rear in the shop and a 4.11 too but im not positive
Old 11-02-2007, 12:16 AM
Okay, several things:
the diff, its out of a manual.. dang
so I'm getting 4.44 gears in my car when I do the swap? Bet it'll be wicked fast
Tom, how much would you want for the 4.44 diff? I could really use it
Now, I can just take the trans, the ring & pinion swapped diff to my local trans shop and just tell them to put it in, right? There isnt too much involved in this swap, just a simple bolt-in job. I got a quote of $400 to put a used transmission in, which seems fair.
What parts of the exhaust will need to be disconnected, my bolts and gaskets are quite old.
Finally, is there anything else I should optimally get done while the trans it outta the car? anything hard to get to normally that would be a good idea to do?
