Door locks won't work
Help I locked my car went into the store and when I came out I could not un lock it. I climbed thu from the Pass side when I got home the door will not unlock from inside or outside. If I put down the window turn the key to un lock pull up on the inside unlocker and pull up on the out side door handel it will open. Any suggestion seems like something slipped. Auto door lock remote is shot. Had this happen once before but forgot how i cured it.
for my car the issue was the contacts inside the door lock motor assembly. I took it apart a couple of times, but ultimately ended up replacing the whole assembly.
part #2 on this page: http://www.subaruparts.com/diag/?mod...category=602-A |
Thanks ! When you said contacts I said oh sure it is electric. I pulled the 15 amp fuse out and it looked good I said darn I thought I had it . I closed the door and now everything works it a DAM SVX magical moment I tell you <LOL> See you helped more than u know.
