1992 SVX Vanagon Synco, loss of ignition?
Hello,
This is my first post. Firstly I have a 1987 Vanagon Syncro Camper with a 1992 SVX motor and computer. I have maintain and enhanced the initial installation. I have a new issue: Cruising along I will get loss of power as if I've taken my foot off the gas, the motor does not die. Then the motor will "catch" again. This is a intermittent problem, some days lots of cut outs, some none but it seems to be occurring more often. I checked the TPS sensor and even replaced it with a known good sensor. Same issue. I'm in the process of pulling any codes but having to find the wires I put away a while back. The only other thing i've done since install is replace one coil over. That coil over was crumbling apart it seems. Any suggestions welcome. This is the best motor to power the heavy framed synco, it just cruises down the highway. I don't have the svx car obviously but I do rebuild automatic transmissions and all shorts of motors, rear-ends and other gear so I won't hesitate to help if I see a question that's appropriate. Update: Code 33 and 29, I think I've always had 33 (speed sensor) but 29 is the crank angle sensor, hum is this one of the unobtainium parts? Appreciate the time, dp Last edited by vwroad87; 04-22-2018 at 03:58 PM. Reason: Update with Codes: |
Re: 1992 SVX Vanagon Synco, loss of ignition?
Well I'll reply to my own post, the fix was a MAF, I used one from a Legacy, 25 new on ebay, works great!!
I didn't see your original post. My answer while reading today was MAF. They can often be re-soldered with excellent success if you want to keep your old one for a spare. There's info on the site here.
I have a tranny question for you. My '97 often searches between overdrive and drive, shifting up and down for no reason while cruising along at a steady speed. It was bad when I first got the car out of storage this spring and has improved a lot. My initial thought was the TPS. The lack of responses may be the general disdain for anyone robbing an SVX engine for another purpose. My opinion is that at least the heart is still beating even if the body is dead.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 05-13-2018 at 04:11 AM. |
