SVX Won't Start... Fuel Pump?
My SVX died on me in the middle of road yesterday and wouldn't start. Had to get towed back home. It cranks and sometimes catches but then immediately dies. (But, mostly just cranks.) It has done this twice before this past summer. The first time it started back up again after 10 or 15 tries. The second time it started up after I had a friend come over to look at it and we had barely begun to diagnose it. I've checked the fuses, replaced the battery, replaced the fuel filter, and tried swapping the MAF sensor with a known good one.
What should I do now? Where can I check to see if the fuel pump is getting voltage? (I think it has a relay under the steering wheel.) Or is it probably something else entirely? Thank you for any help. UPDATE: I just got code 37 for the oxygen sensor. Would this cause my problems? Last edited by daristotle; 09-21-2010 at 02:45 PM. |
Re: SVX Won't Start... Fuel Pump?
Alright, so today I tried starting the car several times, checked for codes, then checked for voltage at the main relay. There was voltage. I then disconnected the 'in' hose to the fuel filter put it in a bottle and turn the key to the on position. No gas came out. Then I removed the rear seat and checked for voltage at the wiring harness there. I got voltage. I tried starting the car and it fired right up. Let it run for a minute then turned it off and then back on. Ugh. What should I be checking next here? I really don't want to stall out in rush hour traffic again.
Not sure if this relavent but I believe my problem like this was something to do with the fuseable link.
Just a thought
- Sonny [1992 LSl, Claret 160k] / [1992 LSl, Dark Teal #378 172k] / [1992 LSl, Claret 150k] / [1992 LSl, Liquid Silver donor] / [1992 LSl, Liquid Silver 4.44] / [1997 LSi, Polo green #089, 150k] 1992 Chevrolet Lumina Z34, white 35k miles 1992 Chevrolet Lumina Euro, charcoal grey >200k (first car) 1992 Chevrolet Lumina Euro, charcoal grey >200K (for sale) 1986 Honda VF500F Interceptor 1994 GMC Jimmy S-15 |
I checked the fuseable link and it seemed good. I drove the car today to the auto parts store to have the alternator tested. (It tested good.) On the way home the check engine light came on and I got code 37. (Oxygen Sensor No. 2, Left Side, On SVX.) I was still able to drive the car home and the performance didn't seem any different. Could this be the source for all my problems or yet another problem?
I started having similar problems just today coming home from work. First my car feels like it wants to shut off while driving, and honestly the closest thing I can compare the feeling to is when my other cars electronic speed governor came on and shut off the fuel to the engine. Exact same feeling. Then when I get home and it wants to stall constantly. Any advice would be welcome.
fuel pump relay? shouldn't you get 2 x 12 volt readings at the pump connector under the seat? one for the pump and one for the gauge?
SVX , XV Impreza, H6 Outback Last edited by legacyau; 09-24-2010 at 01:25 AM. |
