Trunk release failure?
All of a sudden my trunk will not open. I pull the release lever by the driver's seat and hear the usual click, but then go back to the trunk and it is not popped and will not lift - even as I pull up enough to get the car up off it's shocks an inch or two.
Is it possible something suddenly broke in there? Unfortunately, I can't open the trunk with the key, as I've owned the car 10 years and never had more than the valet key! (yes, for 10 years meaning to get a dealer to see if they can order a key based on VIN or something) Is this a common failure? Is there a way to open the trunk from inside the trunk? Or is my trunk permanently sealed forever? Really bad timing on this as I'm in the middle of R&D for a new trunk strut solution.... having only one worn out strut installed currently shouldn't be causing this, should it?
Troy 1992 SVX LSL "Serenity" 250,000 miles! I don't care, I'm still free, You can't take the sky from me... |
Re: Trunk release failure?
There is a switch that is on the trunk latch itself that will cancel the function of the pull trunk release. So you may be able to crawl through the back seats to check that but I'm not sure if there is actual access to it with the trunk closed.
You can access it through the back seat, provided the back seats are not "Locked" by the switch on the seatbacks.
There is enough room to feel the cancel lever from where the trunklid closes and move it. Even I did it with my extra-large "sausage-fingers" .
That leaves a very interesting image in my mind!
Funny, that's what all the ladies used to say.
This one has got me a few times.... its easy to switch the lever accidentally and not notice. |
Yeah I knew all about the trunk lock lever on the latch but like an idiot didn't try that first. I just figured in 10 years I've never accidentally triggered it, so why would I now?
But yeah, that was it. Most likely since I only had one trunk strut when I closed it the trunk was slightly skewed and the latch hit the plastic trim piece with the opening in it on the way down.. Sorry for making a whole thread about it, but maybe it will help someone who isn't aware of the switch. Or someone who isn't aware of what meat by-product John's fingers most resemble.
I am glad to find it was only operator error instead of a real problem.
What a rookie!
I'm hoping this is my situation now.
When entering the boot from the back seat side, exactly where should the lever be placed so I can use the trunk release mechanism? Horizontally pointing left (seen from the back seat) or vertically down? Br, Reid
I got my girl, I got my glass, I got my car and I'm ready to f... |
