Old 01-04-2009, 09:32 PM
storm66's Avatar
storm66 storm66 is offline
Imagine...
ABS Removal
Has anyone removed the ABS parts and by-passed the brake lines? Any threads I can read or how-to info available. I appreciate your help.
I know you may ask why. Answer: I don't like the way it looks and I for one don't see a benefit from it. Plus it adds weight up front.
Old 01-04-2009, 09:39 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: ABS Removal
Well the ABS pretty much lets you preserve steering control under hard braking, so you can still swerve around obstacles instead of locking the brakes and skidding into it. For a snow car, ABS is pretty vital. As for removing it, the weight saved would be in the few pounds range....... and some secondary issues will arise, like the ABS light and the value of the car to prospective buyers (you never know). You also might want to check out any legal issues with modifying factory safety systems in your state.
Old 01-04-2009, 09:48 PM
Re: ABS Removal
ABS can legally be removed as long as insurance companies are notified. You also lose a relatively substantial amount of weight considering its location from the front wheels. The pump weighs a good 10lbs at least, couple lbs for the extra lines used and then a couple for the controller. Gram or two for the bulb in the dash too. I have to agree that the system in the SVX is a rapid fire and works very well for keeping the car under control. Used it quite a few times in hard braking(120->40) at Pocono and may have very well saved me from going off the course. It also works well in bad weather. So unless you are making a car for race purposes where a good driver is an ABS unit, I would leave it in the car
Old 01-04-2009, 09:49 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: ABS Removal
Ancient ABS is more dangerous than no ABS. I removed it from every 240 I had, my VR4, my old GC Impreza, and my old FC. You're better off without it. Way too unpredictable, both for safety and performance. I don't know if it got any better after 92, but if it didn't, I'd say we're all better off scrapping it.
Old 01-04-2009, 09:50 PM
Re: ABS Removal
read my above statements. The SVX ABS is quite on par with modern units and its functionality is great both for performance and safety as long as it is all working properly
tom
Old 01-04-2009, 09:59 PM
Mensaf's Avatar
Re: ABS Removal
I saw it pop up after I posted mine. My ABS is still there since I've got a number of things to do before worrying about that, and I haven't tested its limits at all. I've become very familiar with the point before lockup and whatnot with the other cars, so it feels odd regardless (only real experience was icy roads in recent weeks.)
The ABS on my vr4 was particularly frightening, which is really bad for a car that weighs in a few hundered lbs more than the SVX does.
Old 01-05-2009, 05:48 AM
Re: ABS Removal
I have to say that the abs system in the Svx is by far the best i've ever experienced and is ahead of some of the current systems. For instance, on our 02 Durango the brakes actually do lock up for a split second, then releases and then locks up again and will continue to do this. My dad spun it around one time and a few weeks ago I would have either rearended a plow or spun out on the freeway because of it had I not had plenty of experience with non-abs cars. The abs on my 95 cutlass was alright but it helped I had goodyear triple treads that were new and my 99 grand prix worked fine even with bald tires.
I was actually surprised at how well the abs system was in the svx the first couple times it engaged. Now, I don't even worry about weather or not it will kick in because it works as it should.
